whinig noice, bad ground?
Discussion in 'Mustang Sound & Shine All' started by TenaciousD, Jul 7, 2007.
  1. TenaciousD Founding Member
    Sep 15, 2001
    Message Count:
    324
    Tampa,Fl
    I did a search but couldnt fine what i was looking for, I had alpine head unit iinstalled a yr ago and have been liiving with a whining noice that get louder with thr increase of RPMs or pressing a power button such holding down the power window button. I've kinda got use to it but im looking to sell and upgrade mustangs and i want everything to be right when i sell it. I have hear two different reasons why this may be happeneing, a bad ground or i need a filter? ( the last siggestion came from a stereo store, same ones who installed the unit so im not really trusting them.
    thanks for any help
  2. ChingonStang Member
    Sep 19, 2004
    Message Count:
    867
    Dallas, Tejas
    Are you using aftermarket amps also in conjunction with the Aftermarket head unit?
  3. TenaciousD Founding Member
    Sep 15, 2001
    Message Count:
    324
    Tampa,Fl
  4. Supradude26 New Member
    Oct 12, 2005
    Message Count:
    86
    If you are still using the Mach amplifiers, then you need to have a line level adjuster installed to lower the signal going to the factory amps. This is a common problem with some Mustangs that have a aftermarket stereo installed using the factory Mach amps. The line level adjuster is simply a box that is wired in between the new deck and the factory speaker wires, and they usually have 4 gain adjustment knobs to dial in the output.
  5. TenaciousD Founding Member
    Sep 15, 2001
    Message Count:
    324
    Tampa,Fl
    thanks.
    I was able to get it all sorted out the other day.
    now all i nee to fix is the abs light problem which i hop is just the sensor/module
Share This Page
