Wide Rims???
Discussion in 'Fox 5.0 Talk' started by thojoewen86, Apr 29, 2007.
  1. thojoewen86 New Member
    Apr 13, 2004
    Message Count:
    22
    I just bought a notch project that already has minitubs but I dont have the $ in my budget to do a 5 lug swap. Is there somewhere I can get custom 4 lug rims. Id like to get the 2k Cobra rims in 17x10.5 but I cant find them any where in 4 lug. I would like to fit a 315 tire in the back if posible. Any suggestions?
  2. mob the guy who hits on his mom
    Oct 3, 2003
    Message Count:
    2,140
    56
    if you dont have money to do a five lug swap, you wont have money to buy 4 lug wheels over 9 inches wide.
  3. thojoewen86 New Member
    Apr 13, 2004
    Message Count:
    22
    I dont have the money to do a 5 lug swap and the get 4 new rimes. The car has 2 17x9 Cobra rims but I wanted to get a set of wide rims for the rear.
  4. Npower New Member
    Oct 15, 2006
    Message Count:
    not sure on the wheels but I have 17x10.5's with 315"s and it fits...with some minor adjustments ;)
    but I did do a 5 lug swap, maybe try oem wheels distributors out of florida they may make some in 4 lug.
  5. mob the guy who hits on his mom
    Oct 3, 2003
    Message Count:
    2,140
    56
    im just saying, to find wheels in 4 lug and over 9 inches wide, is probably gonna have to be something from CCW and its gonna cost you like 1 grand a wheel.
  6. soontobefastfox Member
    Nov 15, 2005
    Message Count:
    275
    I think over 9.5" wide would be hard for 4 lug wheels, I have 4 lug ROH ZS racing wheels which are 17x9.5", but I doubt you can fit 315 tires without modifications.
  7. JohnnyGMachine Member
    Jun 20, 2004
    Message Count:
    105
    18
    I just cannot hold it in I have to say it. Some people have done it and they think it looks great even though they scrub bad and can't lower the car right - meaning the front will be low but it's obvious the rear is left up higher in the rear because the rear tires stick out even more than the fronts. I have seen several fox body Mustangs with 17x9 front and 17x10 or 17x10.5s out back. It's just too wide for the car. Reality is that the optimum size tire for a 17x9 rim on a Mustang is 275/40/17. I see guys STRETCH a 245/45/17 on a 9" wide rim and it just doesn't look right and there's a possibility of the bead of the tire popping off the rim under extreme cornering not to mention the danger of scrubbing the tire at high speeds and shredding it. Unless you plan on doing a minitub - doing it the right way or more importantly the SAFE way - a 10" or wider wheel doesn't fit inside the rear fenders of a Fox Mustang. I guarantee a 315 will sit atleast 1" outside the fender lip on a fox Mustang. What is wrong with a 17x9 out back and a 17x8 out front? It looks killer and is PLENTY of meat for that car. I've seen very few cars that have the right mods done to the front suspension to make a 9" wide wheel fit properly. I am getting ready to do a 1-1.25" minitub on my notch and then I can fit a 10-10.5" rim out back just inside the rear fenders with no scrub and I can lower it 1.5-2" like planned. All I'm trying to say is if you're gonna go with ultra wide wheels and tires - don't force fit 'em - make it fit right. Atleast get a wheel with the correct offset to properly fit in the fenders. I saw a nice custom notch at the Commerce Drag Strip a couple of weeks ago with 18x9 bullitts up front and 18x10.5 bullitts in the rear. The tires were grossly stretched on the rim so they would "tuck" which they didn't and still stuck out. I walked up with a couple buddies for a close inspection and every single tire sidewall was cut or scrubbed severely and not to mention it looked like terrible with the wheels sticking out past the fenders. I started noticing a trend when the guy got out of his car and his pants were so big and baggy that he had to keep pulling them up to keep 'em on. I was noticing a trend....
    Sorry for the rant but be realistic - buy equipment that fits your ride and make it driveable and safe.
    J
  8. Npower New Member
    Oct 15, 2006
    Message Count:
    Your right it is all about getting the right often custom wheel if you go 10 or 10.5 in the back so it fits...I had to.
  9. SuperStang83 Founding Member
    Mar 21, 2001
    Message Count:
    1,774
    48
    If he has mini tubs what is the big deal about fitting a 10 inch or wider wheel? Go for it man you should have no problems getting that ti fit. You should just put spacers on for now or get Ponys widened until you can afford 5 lug.
  10. ryan218 In just 10 years, I'll be old enough to drive!!!!
    Dec 29, 2005
    Message Count:
    214
    27
    get some 10 holes or pony wheels and chop to in half...then widen them... pay someone to do that...cheaper then new wheels
  11. 25thmustang Active Member
    Sep 5, 2003
    Message Count:
    1,959
    48
    My friend has 315 Nittos on 17x9s and they fit fine!
  12. thojoewen86 New Member
    Apr 13, 2004
    Message Count:
    22
    The car has at leat 1.5in minitubs with full coilovers. There is pleanty of room in the back I just dont know where I can get the wheels for it. I was hoping there was a website or a directory for these kinds of wheels. If a 315 will fit on a 17x9 then ill go for that but I cant imagine it would, right now it has a 285/45//17 and I cant imagine something much bigger.
  13. 25thmustang Active Member
    Sep 5, 2003
    Message Count:
    1,959
    48
    315 Nitto DRs will fit, my friend runs them and they fit fine! Nittos run very narrow though, so if a 315 Nittos fits, a 315 BFG will NOT!
  14. iwashmycar New Member
    Apr 8, 2004
    Message Count:
    1,366
    9
    well heres an idea...i didnt read much of the thread lol.....but if you can only seem to find the 2 wheels you want in 5 lug, then just grab some 5-lug ranger axles cheap and then have 5 lug on the rear, until you get the front done to match......Just an idea....cant look THAT bad...can it? I mean its true...your not gonna get "custom" 4-lug wheels any cheaper
  15. Shakerhood Active Member
    Oct 29, 2004
    Message Count:
    2,535
    46
    I did not even realize you could have your wheels widened, I wonder if it would weaken the wheel.
  16. thojoewen86 New Member
    Apr 13, 2004
    Message Count:
    22
    what shop would widen wheels? Ive never heard of that
  17. Flavadave4 Active Member
    Nov 29, 2003
    Message Count:
    1,063
    48
    Right on, I have the same wheels and with 275's in the rear i had to flip the quad shocks.......its still a tight fit with little to spare!
  18. JohnnyGMachine Member
    Jun 20, 2004
    Message Count:
    105
    18
    Sorry man, I musta read right past the part where you said "minitubs". AFS sells 4 lug Cobra wheels.
    www.afswheels.com
    Their website seems screwed up but if you call you can get them from them. They also sell wheels on ebay a lot. You can also find them there and they will honor those prices as well if they are cheaper on ebay than their site. Sorry guys about the rant on wheel fitment but I'm so tired of seeing a nice fox ruined with wheels that don't fit - no more on that.
    The 17x9 4 lugs almost fit up front even with a 245 on them. The tire looks too stretched and will still rub the fender if you lower it too much. I think however I saw a guy that had the back of the wheel face machined down a couple mills. I would have somebody who knows what they're doing look at that first to make sure there's gonna be enough "meat" for safety. Some guys pulled their LX into Mustangs Unlimited and he had the 17x9 03-04 Cobras on the car with 245s on the fronts. They had it lowered atleast 1.5" and he said yeah it rubs a little on a turn if you're going a little too fast ??? but he liked it. I followed him out onto the highway and watched it - man that front tire was all over that fender lip - no thanks.
    I guess my only advise is measure, then measure again. Then again. Do your homework before you spend your hard earned cash.
    As far as the 5 lug conversion, you can go the cheap route temporarily and get the kit with the 5 lug front rotors, 5 lug axles, drums, oil and bearings for about $400 too.
    J
  19. thojoewen86 New Member
    Apr 13, 2004
    Message Count:
    22
Share This Page
