Will my computer like my cam?
Discussion in '94-95 Tech' started by nickm347, Nov 18, 2004.
  1. nickm347 New Member
    Jul 13, 2003
    Message Count:
    162
    Im doin a 347 stoker motor with a big comp cam(sorry i forgot the exact specs, and i know its imprtant). my question is how well will the computer hold up with this untill i can get a tweecer or computer tuner of some type. i have a JET performance chip in it right now, will that do fine for now, or should i be expecting some trouble when i get my motor in?
  2. 1hot5.0 Founding Member
    Sep 7, 2002
    Message Count:
    1,616
    I don't know for sure, but from what I have read, our stock computers do not do well with aftermarket cams at all. I know the idle would surge alot and all but I would think the car would at least be driveable? :shrug:
  3. SlowGT Founding Member
    Jun 17, 1999
    Message Count:
    834
    define 'Big'...
    Crower, CompCams, Crane & Lunati all recommended keeping duration @ .050" less than 230 when using an unmodified/unchipped stock computer. Biggest I've seen without any significant issues is the CompCams XE274HR with 224 int/232 exh @ .050".
    You'll probably get a lot more accurate feedback if you put up the cam specs :nice:
  4. fawcett New Member
    Sep 11, 2003
    Message Count:
    378
    i have an e cam in my 95 and the computer hates it. i was told to get a steeda #19 but i didnt, they are made for our cars. i really wish i went with something my car would like, but i didnt. now i have to get a pms or tweecer- something you might want to consider also. from what i have heard, chips dont do it, we need something more. i have never used or seen either tweecer nor pms (except in the magazines and on the internet) but as soon as i grow a sack, im gettin one of those so my car doesnt die everytime i come from wot to a stop, or sometimes just come to a stop.
    good luck buddy
    fawcett
  5. Joes95GT New Member
    Jan 23, 2003
    Message Count:
    3,153
    My cam is smaller than that on both sides and my car would die EVERY SINGLE TIME when I came to a stop. Our computers seem to not like tight LSA's either. Comp's cams are usually a 114 (+4) design, so you probably won't have a problem there. It will just be an issue of excessive duration.
    Joe
  6. canadian94gt New Member
    Dec 25, 2003
    Message Count:
    139
    I've got the xe274hr and it idles fine. I had to set the idle at about 900 before I got the tweecer. Now I can idle at 700rpm and it sounds really aggressive.
  7. nickm347 New Member
    Jul 13, 2003
    Message Count:
    162
    i dont remeber the specs on my cam, so i figured i would say it is"big" just to be safe
    it looks like my JET performance chip isnt going to cut it
    does anyone have a rough idea on how expensive a tuner for the computer will be?
  8. canadian94gt New Member
    Dec 25, 2003
    Message Count:
    139
    I think tweecer is backordered. They go for around $600. You can pick up a used one off ebay or corral classifieds for between $400-$500. Make sure to get the RT model if you want to do datalogging plus it hooks up with just a USB cable. They really are worth the money. Since you can modify things as you add to your setup. It also gives you five different tunes that are at the twist of a knob. You can have a race tune, a city driving tune, a highway tune, etc.
  9. HoofnIt Founding Member
    Jan 8, 2001
    Message Count:
    1,171
    If you're worried about cam/computer compatibility and you're going to get a tune or EEC tuner later then don't let the computer affect which cam you choose. Choose the RIGHT cam for your combo and let the tune take care of the computer. I went with a Crower 15511 hoping I wouldn't need a tune but if you're going to spend all of that money on performance it only makes sense to have a custome tune to make it work up to it's potential. I got a SCT custom dyno tune w/17 pulls for $375. Yes, it's a one-time tune but I don't plan on making any major changes to my combo for a long time. My car has a noticable lopey idle but the driveability and performance are great after the tune.
  10. final5-0 New Member
    Apr 7, 2003
    Message Count:
    6,803
    BINGO :banana:
    This Man Wins the Prize :nice:
    Only difference is I like to do my own tuning.
    Later
    Grady
  11. greenlantern New Member
    Jul 11, 2004
    Message Count:
    263
    I must be the only one who lives in a state where emmissions, is an issue. I would love to switch out my cam for a more aggressive profile but I've got one problem. EMMISSIONS The emmissions here in Mo are a strickt. Aggressive cams are a sure way to flunk your test. Im sure sombody must make a cam with this in mind but where do you look? And if such a cam exist does the horsepower you gain justify the cam swap?
  12. final5-0 New Member
    Apr 7, 2003
    Message Count:
    6,803
    I live in the DFW area of Texas and we have to pass the dyno roller kind of emissions test yearly. We also have those state owned step side vans that put out those sniffer probes that park at highway on ramps and test cars that pass by for dirty emissions.
    My cam is not mild by any means and I have no problem passing the emission inspection and have passed it for the past two years.
    I am one example that has to challange that statement.
    Ed Curtis, Jay Allen, Buddy Rawls
    I don't think my rwhp & rwtq would be near what they are now with the stock cam so my answer to that statement would be .... YES the cam swap was worth the gain in horsepower.
    Later
    Grady
  13. Joes95GT New Member
    Jan 23, 2003
    Message Count:
    3,153
    The cam can be aggressive as hell. My cam has ZERO overlap at 0.050", so it should pass. For big companies to get a CARB number for an OTS cam, they need to have zero overlap @ 0.006". Any of the aforementioned names could make you cam that runs cleaner than the stocker with tons more power.
    Joe
Share This Page
