Winter project help!!!
Discussion in 'Fox 5.0 Talk' started by Turkey Sammich, Nov 8, 2006.
  1. Turkey Sammich I can't fap normal. I cracked a rib, then my ankle
    Jul 13, 2006
    Message Count:
    2,711
    183
    83
    I'm currently running a 93 LX, with the following:
    3.55 Gears
    E303 Cam
    Subframe Connectors
    Offroad H Pipe
    Flowmaster Exhaust
    Fuel Pressure Regulator
    Short Shifter
    I need opinons on the next step to take with this car, performance wise.
    I'm looking to add more hp to the car. What does almighty :SNSign: community advise I do? :hail2:
    * Note: I plan on going with a head/cam/intake but, I would like advise on what to do before I go that direction.
    Thank you.
  2. grey5.0beast Cookies should never be DUNKED!!!
    Aug 3, 2004
    Message Count:
    451
    39
    atl ga
    not much you can do to gain a bunch of power before HC, except maybe a s/c, or a bunch more boltons, but even then you won't see a big gain.
  3. Turkey Sammich I can't fap normal. I cracked a rib, then my ankle
    Jul 13, 2006
    Message Count:
    2,711
    183
    83
    I was thinking about adding a 70mm TB, & bbk fenderwell cold air intake. Then shortly after Cobra Intake & Heads.
  4. grey5.0beast Cookies should never be DUNKED!!!
    Aug 3, 2004
    Message Count:
    451
    39
    atl ga
    meh cold air intakes are for looks IMO. a kand n in a stock box w/ no air silencer is just as good, if not better.
  5. onefstsnake New Member
    Nov 25, 2005
    Message Count:
    819
    Northern VA
    you will gain the most power from the O/R H.
    The cam will help out a bit. And the gears will give you a nice SOTP increase.
  6. grey5.0beast Cookies should never be DUNKED!!!
    Aug 3, 2004
    Message Count:
    451
    39
    atl ga
    thats what he has as of now, he wants to know what to do next :doh:
  7. PJB New Member
    Aug 23, 2006
    Message Count:
    379
    Rotterdam, NY
    The cats are that much of a restriction?
  8. Turkey Sammich I can't fap normal. I cracked a rib, then my ankle
    Jul 13, 2006
    Message Count:
    2,711
    183
    83
    :lol:
  9. grey5.0beast Cookies should never be DUNKED!!!
    Aug 3, 2004
    Message Count:
    451
    39
    atl ga
    yes
  10. Turkey Sammich I can't fap normal. I cracked a rib, then my ankle
    Jul 13, 2006
    Message Count:
    2,711
    183
    83
    I admit. The cold air intake is for appearence.
  11. onefstsnake New Member
    Nov 25, 2005
    Message Count:
    819
    Northern VA
    which H/I are you thinking about?
    I would go with a 65mm TB, Underdrive Pulleys (leave out the Alt.), and a set of headers. 1 3/4" shorties...
Share This Page
