Wiring question
Discussion in 'Mustang Sound & Shine All' started by yamie700, Aug 2, 2004.
  1. yamie700 New Member
    Aug 27, 2003
    Message Count:
    67
    MN
    Sorry if this is dumb but I am getting ready to ditch the entire Mach 460 system and need some advise. I have a JVC head unit that is like 45w x4 max power and a 4 channel Kenwood amp that is like 35w x4 rms. My question is when I wire my 4 new speakers should I just run power from the amp or should I use the amp + the head units power. Basically should I just let the head units power do nothing?
    I will be using 2 Infinity Kappa 5x7 and 2 Cerwin Vega 5x7. I hope that I did not wreck the Cerwin Vegas as I installed them for a short time with the stock system before I knew the ohms were way off witht the 460. What is a good way to check and see if they are ok?
  2. yamie700 New Member
    Aug 27, 2003
    Message Count:
    67
    MN
    Anyone??
  3. KAILUAZ New Member
    Jul 15, 2004
    Message Count:
    341
    St Pete, FL via Kailua, HI
    You could bridge your amp to get more power to one set of speakers, then just run the other set off your head unit. Just make sure when you bridge the amp your speakers can handle the RMS max.
  4. MyEarsHurt New Member
    May 21, 2004
    Message Count:
    926
    First off your cerwin vegas are fine, secondly I would just use the 4 channel amp, and not wire any speakers to the head unit. The head unit you bought is probably somewhere around 23 watts rms per channel, and the 4 channel you have is 35 watts rms, so go with the four channel. As for bridging the amp like KAILUAZ suggested, I wouldnt. From my experience, when you run one set of speakers from the head unit, and one set from a seperate amp, you tend to get a little echo effect because not all the speakers are going off at the right time. It could be a matter of less than a 1/2 a second, but you will notice it and you will probably not like it. So either way you go, I would avoid bridging the amp, just my opinion.
Share This Page
