Your Input: Bilstein
Discussion in '2005 - 2012 (S-197) Mustang' started by Wind-Farmer, Dec 11, 2008.
  1. Wind-Farmer Member
    Sep 2, 2008
    Message Count:
    271
    Minnesota
    Hey guys,
    I was looking around at the different shocks and struts out there. Tokico D-specs are pretty apealing. I will never be running road course so the adjustable is not really needed for me. Plus, the scare of blowing a seal with the adjustment valving is also pushing me away from them.
    I have came across the Bilstein front and rear shocks and struts, $605, same as the Tokico's.
    I don't see the Bilstiens on many sites, only on a select few; I find that very interesting, almost seems kind of.. shady?
    Are they true Bilstiens, will they live up to the Bilstein name, are they worth it?
    I am looking for a good, non-adjustable shock, strut setup. Using them in conjunction with the Eibach Pro-Sport springs.
    What do you think about these Bilsteins?
    Thanks guys.
  2. gashog Member
    Dec 26, 2006
    Message Count:
    217
    Fresno, CA
    Bilstein's have quite a rep with the european crowd, they are a very reputable brand. I'm running the Tokico HP's (non adjustable) and they are very solid feeling. I bought the set of 4 for $325. I don't intend to take the car too often (might see dragstrip occasionally) and they work great as a DD option.
    Just my .02
  3. SpartaPerformance StangNet Sponsor
    Nov 5, 2006
    Message Count:
    1,815
    38
    Long Island NY
    Ever think of calling Eibach and see what they recommend? They may be able to point you in the right direction of best shock set up based on their spring rates.
  4. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
    my 2000 S10 Xtreme came with bilstein shocks as OEM equipment. they were very nice, especially with a lowered truck. i have never installed them as a replacement for stock, so i cannot compare between a stock and a bilstein replacement.
    FWIW, J&M sells the D-specs for about $500 shipped. that may add to your thought process between the two manufacturers. 2005-2009 FORD MUSTANG TOKICO D-SPEC SHOCKS & STRUTS SET
  5. Wind-Farmer Member
    Sep 2, 2008
    Message Count:
    271
    Minnesota
    Thanks Big Cat, that is a very good find. I am giving some serious thought into this now.
    Is that site a pretty reliable source? Do they package their products well?
    The HP's are also looking pretty apealing, so much out there; its tough.
  6. walter Founding Member
    Aug 13, 1998
    Message Count:
    1,068
    46
    Houston TX
    When inquired about adjustable/coilover setups a racing instructor for MSR told me get yourself some springs and a set of Bilsteins or Koni Yellows and that's all you'll ever need.
    There's gotta be something to them.
  7. Wind-Farmer Member
    Sep 2, 2008
    Message Count:
    271
    Minnesota
  8. walter Founding Member
    Aug 13, 1998
    Message Count:
    1,068
    46
    Houston TX
    They are the same thing. When in doubt check the manufacturer's website and cross reference part numbers.
  9. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
    J&M is a very reliable source. i have their upper & lower control arms, lower control arm relocation brackets, camber plates, stainless steel braided brake lines, adjustable panhard bar, & vogtland springs. ALL have come without any packaging issues.
    they also are a forum sponsor. :nice:
  10. metroplex Member
    Sep 7, 2003
    Message Count:
    401
    There are reports of Bilstein giving customers the run around with warranty replacements (Where the lower mount broke at the welds). I felt my HD Bilsteins were extremely overdamped with inadequate rebound, so my tires tended to hop over speed bumps at low speed and gave an extremely rough ride on bumpy roads. I felt the stock dampers on my S197 GT are more than adequate for road use as they give a good balance of comfort and handling. The track is a different story.
  11. Wind-Farmer Member
    Sep 2, 2008
    Message Count:
    271
    Minnesota
    Thanks metroplex, I have the tokico D-specs order :)
  12. shooterm1 New Member
    Jul 19, 2005
    Message Count:
    546
    Milford, Pennsylvania USA
    why not get the Tokico Sport shocks then?
    same great engineering, but without the user adjustment features...
  13. gashog Member
    Dec 26, 2006
    Message Count:
    217
    Fresno, CA
    :shrug: I suggested that too.
  14. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
Share This Page
