Question On Systoms Of A Bad Pip Sensor
s7sams
i have a 86 with the sefi 5.0 liter and i have test almost everything i can think of and it is pointing to me at a bad pip sensor inside the distributor. i have a intermittent problem when it acts up i have no spark and no signal to the injectors. but when this happens i also appear to have low fuel pressure. i say appears due to the fact that when i press the schredure valve it will just barely squirt out. by the time i get the fuel pressure gauge out the car will start. i have kept a spare spark plug to check for spark and the node light in the car. for when it acts up.but not the fuel pressure gauge i need to put that in there as well . the car will start and drive fine but when i stop and shut it off sometimes it will not restart for like a hour then start fine. my question is since the injectors are not firing when it acts up would that tell the ecm not to call for fuel and kick out the fuel pump also i can hear it prime when it is acting up. or do i have to different things going on here? any help would be appreciated. thanks
PIP Sensor functionality, testing and replacement:
Revised 17-Jul-2014 to add check for loose PIP mounting screws
The PIP is a Hall Effect magnetic sensor that triggers the TFI and injectors. There is a shutter wheel alternately covers and uncovers a fixed magnet as it rotates. The change in the magnetic field triggers the sensor. A failing PIP sensor will often set code 14 in the computer. They are often heat sensitive, increasing the failure rate as the temperature increases.
Some simple checks to do before replacing the PIP sensor or distributor:
You will need a Multimeter or DVM with good batteries: test or replace them before you get started.. You may also need some extra 16-18 gauge wire to extend the length of the meter’s test leads.
Visual check first: look for chaffed or damaged wiring and loose connector pins in the TFI harness connector.
Check the PIP mounting screws to see if they are loose.
Check the IDM wiring – dark green/yellow wire from the TFI module to pin 4 on the computer. There is a 22K Ohm resistor in the wiring between the TFI and the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 22,000 ohms +/- 10%.
Check the PIP wiring - dark blue from the TFI module to pin 56 on the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 0.2-1.5 ohms.
Check the SPOUT wiring – yellow/lt green from the TFI module to pin 36 on the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 0.2-1.5 ohms.
Check the black/orange wire from the TFI module to pin 16 on the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 0.2-1.5 ohms.
Check the red/green wire; it should have a steady 12-13 volts with the ignition switch on and the engine not running.
Check the red/blue wire; it should have a steady 12-13 volts with the ignition switch in Start and the engine not running. Watch out for the fan blades when you do this test, since the engine will be cranking.
If you do not find any chaffed or broken wires, high resistance connections or loose pins in the wiring harness, replace the PIP sensor or the distributor.
The PIP sensor is mounted in the bottom of the distributor under the shutter wheel. In stock Ford distributors, you have to press the gear off the distributor shaft to get access to it to replace it.
To remove the gear, first you drive out the roll pin that secures the gear to the shaft. Then you get to press the gear off with a hydraulic press or puller. When you go to press the gear back on, it has to be perfectly lined up with the hole in the gear and shaft. I have been told that the hole for the pin is offset slightly from center and may require some extra examination to get it lined up correctly.
Most guys just end up replacing the distributor with a remanufactured unit for about $75 exchange
PIP problems & diagnostic info
Spark with the SPOUT out, but not with the SPOUT in suggests a PIP problem. The PIP signal level needs to be above 6.5 volts to trigger the computer, but only needs to be 5.75 volts to trigger the TFI module. Hence with a weak PIP signal, you could get spark but no injector pulse. You will need an oscilloscope or graphing DVM to measure the output voltage since it is not a straight DC voltage.
See http://www.wellsmfgcorp.com/pdf/counterp_v8_i2_2004.pdf and http://www.wellsmfgcorp.com/pdf/counterp_v8_i3_2004.pdf for verification of this little detail from Wells, a manufacturer of TFI modules and ignition system products.
Dump the codes and look for code 14.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus Digital Ford Code Reader (3145) Equus - Digital Ford Code Reader 3145.
It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
S7sams check you're ecm my lightning did the exact same thing and I traced everything I pulled ecm and found it to be badly burned and would intermittently miss and run crazy amazing that it could run with it being as damaged as it was
Sent from my iPhone using Tapatalk
Don't throw parts at a problem, all you'll accomplish is becoming poorer and more fed up with the problem.
Don't expect anyone to give you better advice until you have done the diagnostic legwork needed to arrive at a good logical conclusion.
The ball is in your court. Get with the program...
attachment.php
What to expect:
Alternate methods:
Hey, jricker...long time fan first time typer, 89 gt 5.0...I've got a no spark no inj pulse issue, everything is new and dbl checked, all sensors, 70mm throttle body,bbk intake 75mm pro m maf for coldair with fenderwell and 19lb inj, grounds, additional 3g 4ga grnd at dedicated computer, computer is new, msd distributor, coil etc, I've also checked and cleaned the salt and pepper shakers, egr and smog deleted, ac deleted, bbk shorty headers, 3core radiator with dbl fans, anyways after all this it's still not running, was but recently quit... found this post and just checked and found power where I'm supposed to on the two red wires when they are supposed to but the other wires do not then I found that all of them, well I put one end of the meter in the drain wire at the computer end and all them beeped when touched at the tfi end...so it must have rubbed somewhere between the two I'm guessing.... would you agree? Also, can cut and run new wires and jumper them in at the computer end or do they pit stop along the way or should I just get a new engine harness? Looks like they are around 300 or so for all new harness I'm just not sure if it goes all the way to the computer...any help would be appreciated for sure...
