Figured I'd share the results of my recent experiment. I got this idea from my FFV Ranger, which I purchased about 18 months ago.
Earlier this year I had the idea of running a blend of E85 through my 86 just to see if it would run any different. I've tried every injector cleaner known to man, and while a difference is noticed for a tank or two, the results don't last.
About a month ago, I ran 2 tanks of E85 blended fuel back to back. I would run the car until the fuel light came on, pour in 4-4.5 gallons of E85 and fill it up with Regular. The car ran funky when cold, once it warmed up it ran ok.
I'm now back to normal pump grade gasoline--89 octane (timing at 12*), and the car runs completely different. Much smoother throttle response, smoother idle, and it seems like it's getting better fuel economy--I haven't checked it closely yet.
Figured I'd pass the info on, from here on out, E85 will be my injector cleaner of choice.
FYI--E85 does NOT eat rubber or cause problems with the fuel system. That's a myth.
The only clogged injectors I have come across here in SoCal were in a car that had been sitting for years with fuel in it.....in a junkyard.
