The Dyno Thread
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
OK, 4.6 land...let's follow suit and have a dyno thread in here.
Submissions need to be in the following format:
your SN user name
### rwhp / ### rwtq
mod list goes here
You can host your own dyno sheet via photobucket (or other host) or I can supply some FTP space as well. Email me if you would like me to host your sheet.
Submissions are to be made via Private Message to any 4.6 moderator, where that moderator can update this thread. Be advised, only posts of dyno sheets and details are going to be permitted to remain in this thread (i.e. only Staffers can post in this thread to update it).
Let's see what you've got! :nice:
CobraM23
278rwhp / 306rwtq
Engine Mods:
PI heads/intake, VT stage II NA cams, Hooker longtubes & offroad X, Magnapak catback, accufab 75mm TB, C&L plenum, Steeda U/D pulleys, MSD coilpacks & wires, JLT RAI, SCT dynotune by Scott Noe
Chassis Mods:
MM full length SFCs, aluminum D/S, PA street/strip valvebody, B&M hammer shifter, 4:10 gear, PA racing tubular k-member, 90/10 struts, foxbody 4 cyl front springs cut 1/2 coil, eibach sportline rear springs
Exterior Mods:
00R hood, cobra front bumper, wingless, badgeless, silver bullitts
'03GTinFLA
256.9 RWHP / 292.8 RWTQ
Perf Mods: Mac LT's, O/R Prochamber, Mac Cat-back, K&N FIPK, Accufab 75 cm TB/Plenum, Predator tune.
Soon to be updated with #'s on Stage 2 heads and Cams with UDP's.
SaleenGT2001
375 HP 385 TQ
MODS
MPH Novi 2000 Mongoose kit 10 psi
Custom Front Mount Intercooler 24x12x3 core
Vortech Mini Race bypass valve
Built Dodge Viper T56 transmission
Aluminum driveshaft
Driveshaft safety loop
Maximum Motorsports full length subframes
Mac Off-Road x pipe
SLP Loud Mouth catback
BBK 75 mm throttle body
SCT custom tune
Lightning 90mm MAF
42LB injectors
Pro 5.0 short throw shifter
Fidanza 14lb aluminum flywheel
McCloud HD 11" clutch and pressure plate
Motive 3.90 gears
Auburn Pro 31 spline differential
Moser 31 spline axles w/ 3" studs
C-clip eliminators
Weld ProStar rims with 275/50/15 M/T Street ET radials
Autometer Lunar boost and A/F ratio gauges
Raptor shift light
Steeda clutch quadrant and firewall adjuster
Dan_Soprano
586.93rwhp 518.66rwtq
04 Cobra, Kenne Bell 2.2 @ 17#, 60# injectors, SCT BA2400 MAF, Catted Prochamber, Magnaflow Catback, K&N FIPK, Full set of Billetflow Idlers.
Da Man...
MRaburn
412.1 hp / 389.7 tq
Stock Catback
Vortech SQ Supercharger w/ Aftercooler
Classic Design Concepts Shaker
Steeda Supercharger Tune
Dual Fuel Pumps In-tank
Tremec T-56 6-Speed
Steeda Sport Springs
MAC Stainless Prochamber
Pro5.0 6-Speed Shifter
Pro5.0 3.73 Gears
Autometer Boost and Fuel Gauges
18X9 Bullitt Wheels
Goodyear G3 275/40s
MGW Accessories
Fiore Firewall Adjuster and Quadrant
ForPointSex
256 rwhp / 296 rwtq
K&N drop-in, Densecharger TB to MAF tube, C&L Plenum, Accufab 75mm Throttle Body, Steeda Under Drive Pulleys, Magnaflow catback, Magnaflow catted X pipe, Mail order SCT Xcal2 Flash Tune from Modular Depot.
Jivepepper
515rwhp / 453 rwtq
Vortech V1 S-trim @ 13psi
MMR mod 900 shortblock
Houston performance S292 cams
stock heads and valve springs
stock intake
Professional products 75MM throttle body/plenum
Mac lt's/or h-pipe/catback
ebay intercooler
afm power pipe
2002GreyGT
242 rwhp / 285 rwtq
Engine Mods:
Tuneable Induction Intake
BBK 75mm T/B and Plenum
MAC Catback Exhaust
Bullitt Suspension
MGW Shifter
MM C&C plates
Full Length Weld in Sub Frames
13" Cobra Brakes with SS lines
