Hey guys (and gals), I searched the archives, but couldn't find any mention of this problem, so I'm hoping somebody knows what's going on...
My mustang:
2000
V6
No mach system
Factory split head units receiver/cassette and CD
Here's my dilemma...sorry if this is long but I figure the more info I give the easier it will be for somebody to identify where I screwed up here...
About a week ago, I turned on my car, and then tried to turn on the radio. It made some low growling kind of noise and then turned off. It wouldn't turn back on since. I first checked the fuses under the dash and they all were fine.
Assuming it was a problem with the head unit, I presumed the head unit had blown out and decided to attempt to replace it. (I was going to replace the head unit eventually, anyway.) I removed the two units from the dash without much problem. I've installed aftermarket stereos before so I didn't think it would be a problem. I had the wiring diagrams, and having spliced wiring before, I was prepared to do that again. If I didn't feel comfortable, I also planned to pick up the harness.
When I looked at all of the connections, I realized none of it matched any of the diagrams I had. Upon further research at that point, I discovered that there is a separate amp under the dash. The connections I had break down like this:
CD player:
horizontal 5 wire connector--I believe these are the power cables
Black 6 prong rectangular connector attached to a gray cable
Black ground wire
Head unit:
Antenna plug
horizontal grey 8 plug connector--I believe these are the power cables for the head unit
Black ground wire
Black 6 prong rectangular connector attached to a grey cable
Black 8 prong rectangular connector attached to a grey cable
Assuming the last one would have the speaker wires bundled together, I stripped a small portion of the grey insulation. Instead I found bare wires. I patched it up, and bought a harness that attached to the two 8 prong connectors. I plugged them in and spliced the wires to the head unit's harness. I also ground the black ground wire.
At this point the new head unit powers up fine, but there is no sound coming from any of the speakers.
Any ideas???
My mustang:
2000
V6
No mach system
CD player:
Black ground wire
Head unit:
Antenna plug
Black ground wire
Any ideas???
