My 351 build with pics
SMOKEDYA
Dirt-Old 20+Year Member
Jul 13, 2003
3,637
Tucson AZ
Well this will be a slow build but hoping to have it in and running by the end of the year?! But since i'll have it out i want to redo my engine bay (already sanded and filled holes and hid the wires) but i want it better plus i'm changing car colors. Heres what i have a 74 351W that is 40 over,it's a fresh rebuild pulled the bearings and they look awsome cylinder walls are great as well. I bought this complete carb to pan without hearing it run for $300 was kinda leary but after tearing into it and seeing what i see i'm sure it's good! I found one thing that kinda puzzles me and thats where the cam bolt is theres this funny looking spacer? you'll see in the pics below. My plans are for AFR 185 heads trick flow R intake and i will let crane deside on the cam but for now i'm going to have to settle for my GT40P heads that are ported with 1.6 cobra rockers. Like i said it will be a slow build and will update as i do stuff! So for the first pices i got my ford racing rear pick up with screw in dip stick oil pan conversion,ford racing 1 piece oil pan gasket,milodon alumn high volume water pump.
This is the night i brought it home
After teardown and paint today
Here is the weird spacer thing on the cam?
peace
john:p
that "wieird spacer thing" on the cam is a cam balancer. you NEED that. trust me, i forgot to put it back on my car and it ran like crap. no lie, i stepped on it and wouldnt go any faster than 20 mph. I had to take off everything again and put it back on, and ran normal. dont go through the same trouble i did.
god your stupid. lol its the fuel pump eccentric, unless you run a mechanical pump you dont need it...
You are a complete tool. STOP posting on forums suggesting this crap.
:rlaugh:
Cam balancer...CLASSIC.
Maybe check the blinker fluid too...
:lol:
Maybe there was another problem, like say some kind of gasket leak, and by tearing it back down you fixed whatever the problem was............
No thats unpossible........
lol
I work on cars for a living, leaving that off of your engine did not cause your problem.
