If I get staggered wheels, how do you rotate them? Should I just get the same size all around? Is there a bennifit to having staggered wheels?
295-30-20 on 20x10's in the rear, 265-35-20 on 20x8.5's in the front. the rears are awesome, look like steamrollers, the fronts are a bit too skinny for me.
you don't rotate, if you get non directional tires you can go side to side but that's about it.
the benefits are having wider tires in the rear where your putting the power down, where they will be too wide to fit on the front. And i just feel these cars look much better with a big fat tire in the rear.
looks cool. i like the staggered look too; i want 10" on the back and 9" on the front, but with 18" rims. i've been pricing things, and the whole set-up will probably cost me close to $2K, including the new wheels. how much did those tires cost, if you don't mind me asking?
Staggered is the way to go. Don't make the mistake and say; put a 265/35/20 up front and a 275/30/20 in the rear...make sure you go atleast 35/35 front and rear for sidewall height, other wise you will notice the front sidewalls being taller than the rears...and that is not a good look, IMO.
A lot of people don't notice it, but I'm also one that notices that. Even though the height is the same, the sidewall is noticeable (to me). That's why I went with 255/45 up front and 295/45 in the rear.255/45 front and 285/40 rear, lets hear how they look! I think the rears will be smaller than the front
That said has anyone tried running the 285/30/18 setup all the way around? How does the car run that way? Is there rubbing up front?
i bought everything as a package for $1500 to my door from wheelreplica.com, though their website is pretty bad.
well i honestly dont think i have enough sidewall on my car, but because the 30 and 35 is a ratio of the 265 and 295 width, a 265-35 and 295-30 is almost identical sidewall height.
How do you figure that??? If the overall diameter is "pretty close", then the sidewalls will also be "pretty close" if the tires in question are on the same diameter wheel...yes the over all diameter is pretty close...but the sidewalls...different story.
