avoiding the speed density
savvydevil
i purchased my 1st car & beginning the mods on the motor, i am aware that the non cali 88 and below foxbodys are equipped with speed density. i want to do as much as i can performance wise without converting to mas airflow. i will do such when money allows. what can i do without programming or converting my ecu?
Do like I am drive it the way it is and buy everything and do it at once. I have an 87 SD car. I put a K&N filter not a CAI, because when I go MAF I will need a different one. I put headers and full exhaust. I bumped my timing to 14* and added 373 gears. The rest I did was cosmetic. If you do it like you say you will be doing some things twice. You can do the few things I did and still use them later after the MAF conversion.
I've already got my new ECU and harness, Cobra upper & lower, 255lph fuel pump. 70MM TB and DSS 331 rotating assembly. I still need heads, cam, injectors, MAF sensor, CAI and the rest of the little crap to make it right. When I have everything I will pull the motor and do it up.
speed density is good. just gotta get a tune if you change the cam and/or injectors. mass air is just more adaptive and easier to work with. my car is an original speed density car too. i converted it when i rebuilt my motor a few years back. took me all of 1.5 hours.
swapping over to mass air is extremly easy. I did everything I could to avoid switching it over thinking it would cost me an arm and a leg. It hardly costs that much once you buy a cpu, meter and meter plug harness. given the chance again I would do it first. Then you'll have no reason not to do something to your car.
im not against it per say but i am just on a budget as of now. im the type of guy who puts performance 1st. i could care less how it looks. so im trying to get low 13's high 12's before i go for looks. full exhaust woulnt be out of the question would it?
1987 speed density
I ran my 87 for years without mass air. Alot of us did back in the late 80's. I had the usuall motor work done. The idle would just hunt, go up and down and foul plugs easier thats all. Instead of switching to mass air, I went carb.
i had a b303 with no problems. Saying you cant change cams unless you have mass air is not true...
Not saying much?
That's not saying much seeing as a bcam is nearly the same as the stock HO cam with more duration....
Sounds like your cuttin me down... I was just saying you can change cams with speed density because someone else in the thread said no way.
We also had cars with custom grind crower cams with duration well above 250 @ o.50 no problem
So smart guy, tell me the specs on the stock cam and the B303....
While your at it, the X and the Z as well. Hurry up and look it up on the net, times a wastin'.....
I'd show you the taillights on my Harley...
His post is nowhere near as condescending as yours. Is there really a reason to insult him in 2 posts because you disagree about the specs of a B cam?
Much more mature ways to handle that than posting up his mod list and insulting him. Try and be more personable please. Thank you
To tannerc91gt
I think I was a little harsh on you, sorry about that. It was uncalled for and I hope you will accept my appology. This is a great forum and I should have used more sense than attacking someone personally. Sorry Man....
