1992 LX 5.0 hatchback
alanw6
449
memphis, TN
1992 LX 5.0 hatchback (built 306, h/c/i/s-trim/etc)
To start, I'm pretty bummed about posting this ad. :( If you search my username, you'll find years of posts while I built and enjoyed this car. I tried to give this car the best I could, and my intent was to build a very quick, fun street car. This is NOT a drag car, but you can make it one if that's your goal.
1992 Ford Mustang LX 5.0 5-speed (original) for sale. Body has 107,0xx miles, ALL mods have fewer than 10K miles, and built motor was done 2500 miles ago.
I am the 2nd owner, purchasing the car in 12/2002 with 97,000 miles on the odometer. I bought this car bone-stock, down the silencer. I have the original dealer window sticker, as well as the 1992 Mustang sales brochure.
Car is an original 5.0, 5 speed car. I wasn't interesting in do any swaps, hacks, etc with my car.
This was my "toy" project, and has served many hours in my shop, being measured for various new products from my business. Every single mod, including the built engine, was voluntary and done for fun. The original 302 was in perfect working order when removed for the forged internals.
Asking price is $9750.00 OBO. No trades, thank you. My reason for selling is that she must fund my next project, and sadly I can't have both.
All the details are listed below, and I'll post a 2nd reply with plenty of photos. Any questions, please ask away!
Car is located in Memphis, TN and can be seen at the office of Speed of Sound LLC. The link in my signature has the contact information.
Regards,
Alan
Specs
1992 Mustang LX Hatcback (Deep Jewel Green, code PA)
Engine
306 CID small block by BB&T Racing (12/2005, installed 2006)
OEM block
302 main girdle
OEM Crankshaft
Eagle forged connecting rods
JE/SRP Racing Pistons
ARP Main Studs
ARP 2000 Rod Bolts
ARP 7/16 Head Studs
ARP Intake Bolts
ARP Oil pan bolts
Trick Flow Stage 1 cam
Comp Cams Pushrods 6.300
AFR 185 cylinder heads from Keith Craft (2.02/1.60)
Ford GT-40 (tubular) intake manifold, gasket matched
BBK/Edelbrock 70mm throttle body (w/ EGR deleted all the way to software)
Scorpion 1.6 Roller Rockers (clear anodized finish)
50 oz Performance Products Balancer
3G alternator upgrade
New water pump (during engine build)
Felpro gaskets
K&N valve cover crank case vent filter
Exhaust
FRPP stainless short tube headers
Bassani BX X-pipe (with catalytic converters)
Bassani BX catback exhaust (3 tail pipes)
Drivetrain
OEM flywheel
King Cobra Clutch
OEM driveshaft
T5 manual transmission (original)
Ford Motorsport 3.73 gears
FRPP traction lock rebuild kit (during gear swap in fall/2005)
Steeda Tri-Axe shifter
Hurst Roll Control line lock (switch in custom ashtray panel)
Suspension/Chassis
Monroe Shocks/Struts
Eibach Pro-kit Springs
Performance Products street dampeners
Steeda lower control arms
OEM brakes, completely replaced 1/2005
2003 Cobra replica wheels (4 lug) 17 x 9
Nitto NT 555R Extreme Drag 275/40/17 (rear)
Nitto NT 555 Extreme ZR 235/45/17 (front)
Fuel/Ignition/Cooling
Walbro 255 lph in-tank fuel pump (high pressure model)
Vortech T-REX in-line fuel pump
Aeromotive Fuel Pressure Regulator
MSD 6AL Ignition Module
MSD Blaster Coil
Taylor Pro-Race Plug Wires
Autolite 24 plugs
Four Seasons custom dual core radiator
Flexalite Black Magic Extreme 3300 cfm electric fan
CSR 1 qt. overflow tank, clear anodized aluminum finish
CSR billet aluminum mounting bracket, clear anodized finish
DC Controls variable speed electric fan controller
Body/Interior
All original exterior paint
5.0Resto “mass-back” carpet replacement (Titanium Silver)
Restored/rebuilt door panels incorporating custom lower panel
Panel houses MB 6.5 Reference series mid-bass and 1 (25mm) tweeter
Speaker panel is fiberglass construction, wrapped in Select Products HF series vinyl
Secure, stock-looking appearance. Awesome sound quality.
Eclipse 5302 indash AM/FM/CD player
Custom CNC-machined dash mounting plate for Eclipse
Custom swith panel in ashtray location
Xtant 3300c 3-channel amplifier (600 watts total)
JL Audio 12w6v2 in custom fiberglass enclosure
Illuminated amplifier rack, smoked plexiglass viewing window and vinyl-wrapped mdf trim panel
Power Adder
Vortech V2 SQ S-trim supercharger (3.33 pulley for 8 psi)
SCT BA-2400 MAF
UPR Boostmaster pipe (plastic)
K&N filter (inside passenger fender) ASP smog pump eliminator
Ford Motorsport AC eliminator
Tuned by Dynospeed Racing in Memphis, TN. 415rwhp/445rwtq on 93 octane, table-flat AFR. I personally feel there is plenty more power capability, only a pulley swap and tune away!
I've decided to bump this one back up TTT.
The stereo has been removed from the car. The hatch area is empty, and the radio area will have a delete panel in place. The door speakers will stay with the car, along with the crossovers that match them. Besides these stereo components, nothing else from the description has been removed. No performance parts whatsoever have been taken from the car.
The offer closest to $11,000 will drive it home. Title in hand, car located in Memphis, TN. Car can be seen by appointment, most any time.
-Alan
Any pics of the hatch area now that the amp and box are gone? No cables showing, carpet intact?
Beautiful car!
Thanks. :nice:
I don't have any pics of the hatch area, but can take them if you're interested in the car.
There is no carpet in the hatch area, just bare floor pan. All wiring (power/ground/speaker/RCAs) have been spooled up and placed into a small box (inside the tire well). I can *easily* get on the horn with LRS if a piece of hatch carpeting is holding anyone back from buying.
-Alan :flag:
TTT for new offers. :nice:
To clarify one thing from the post above:
If anyone would like the trim panel and sub box (without woofer or amps), I still have it and would include it with the car. If not desired, I'll toss it out or find a local fox owner to grab it.
First off great looking car , i just sold my 89 hatch gt which was about 95 % complete and am in the market. I am wondering about how many miles the car has to date and whether or not you still have the car. I am unfortunately in afghanistan right now and wont be home till sept but i am very very interested in this car. I live in charlotte n.c when i am home so coming to see the car wouldnt be a stretch at all to come see it or get someone to do it for me. If you dont sell can you keep me updated on what is going on with it and i will make time to see the car. My email is [email protected] and i check this regularly. Thanks for your time sir and good luck with the car i hope it doesnt sell for my sake hehe !!!
Sgt A. Henning
Been a while, but this one is back TTT. :D
Think I'm going to get more serious about moving this car, and will place it on a few other forums and in Autotrader @ the current price. It's getting depressing to walk by her every day, and admire the dust...
It's way too nice of a car for that, but I simply don't have the spare time anymore.
Wow what a perfect car. i want it bad. My wife and i decided to get into an older Fox since selling my Terminator and this would be perfect. A little far but I would fly down and pick it up if i can put together the money. I will shoot you a pm after i talk to the bank tommorow, Looking to get a personal loan maybe we can do something.
With no inter/after cooling does the car run hot or heat soak easily? Thanks.
Steve
