arcing would hurt performance but not prevent starting correct?
now that I think of it, I noticed my check engine light does not come on during starting. I'll need to pull the cluster to see if perhaps the previous owner removed the bulb due to egr etc not being connected
I just stopped by here and haven't read everything but...You have spark, you have injector pulse, you have fuel pressure, if you have compression, you have RUN. Now with that said pull a plug. Is it wet? If they got wet and it is flooded it will not start. Remember you may have not had spark with you aftermarket ignition long enough to foul the plugs. And second if it does dry one off enough to spark...BOOOOOOM! The next thought is how did you check spark? Some spark testers will spark with a very weak spark and not light a plug. Try the old screw driver method. You may not really have spark. Same how long has it been since it ran? Is the fuel crap? Spray a little carb cleaner in the throttle plate and see if it fires off of that. Keep me posted.Update... picked up an hei spark testor and after bypassing aftermarket ignition i'm getting spark. Also picked up a noid light and getting injector pulses as well. Fuel pump primes and have 40 psi at the rail, so now i'm totally stumped.
Hey I have one of those! My little clamp broke off and I was testing spark on an S10. I was like "No clamp, hm... My bare hand will be alright!"
