Dropped the crank in, unable to install the rods, did not have a ring compressor.. Should have the long block together by friday.
Where did you get the teskid block from?
also..if you are still on the fence about meth kits, look into DEVILS OWN. Kit was a breeze to install and actually looks good!
Got it from a friend, paid $150 bucks for it
Thanks for the tip, going to check it out!
So you definitely doing meth? Eric G. didn't used to like it. Then he saw how well my car runs after he finished with it, haha.
And as Modular2v said, Devil's Own is a good kit. I have an AIS kit that is nice as well. IIRC, they two kits have the exact same components (pump, tank, nozzles, etc.).
Looking to order new shocks and struts for the car, not sure what set to go with.
I have the Tokico HP blues, and honestly, I'm not a huge fan. They do the job, but are very stiff.
On the dyno now, break-in tune, first pull 400rwhp / 469rwtq on 10lbs, 13 degrees of timing, and AR of 11.15 AFR at the top of the pull.
