08 v6 drivetrain woes
Discussion in '2005 - 2012 Specific V6 Tech' started by RR778, Feb 1, 2012.
  1. RR778 New Member
    Feb 1, 2012
    Message Count:
    My buddy has a manual 08 v6 with the pony package.
    When in a higher gear at low rpm and at speed, if you accelerate or add throttle position it feels like something is spinning and the rear end unloads
    Example:
    At 55 mph and 2k rpm or so in 6th if you add throttle it feel like something is slipping seriously
    However a 0-60 sprint or anything over 3.5k feels pretty strong
    Clutch? But I'd think a clutch would melt at higher rpm
    I thought maybe the rear was spinning cuz it was winter, but I'm not so sure here
    Throw out or pilot bearing?
  2. RR778 New Member
    Feb 1, 2012
    Message Count:
    50 k and no track days on the car, an no posi-trac
  3. Fox3v New Member
    Aug 13, 2011
    Message Count:
    12
    sounds like clutch to me...
  4. RR778 New Member
    Feb 1, 2012
    Message Count:
    Yah? Is 50 k about right for a clutch?
    I wonder if that covered under the extended warranty
  5. Fox3v New Member
    Aug 13, 2011
    Message Count:
    12
    cluth wont be covered by warranty
  6. RR778 New Member
    Feb 1, 2012
    Message Count:
  7. mustangford289 Founding Member
    Sep 17, 2001
    Message Count:
    971
    28
    Florida
    The higher the gear and the lower the rpm the less the clutch presses against the flywheel.
  8. Bullitt347 Active Member
    Mar 24, 2007
    Message Count:
    695
    42
    38
    Pacific NW
    Not true. The load or clamping force on the clutch disc is the same no matter the rpm or gear. In a lower gear and at a higher rpm the engine has an easier time in accelerating the vehicle, but the clamping forces of the clutch are the same.
Share This Page
