$130 for a cd player install
Discussion in 'Mustang Sound & Shine All' started by TenaciousD, Apr 22, 2005.
  1. TenaciousD Founding Member
    Sep 15, 2001
    Message Count:
    324
    Tampa,Fl
    Does anyone have a good link or advice on how to install a new head unit in a 99 mustang w/ the mack 460 player. I took it too circuit city just to save some time and it was $50 for the install but as I had a mach 460 he said they needed to "bypass" the amp?? which was another $80.
    I have heard people talk about a harness from crutchfield or metra, is anyone of them better than the other?
    I dont know much about stereo install but I am not paying that much for a simple install.
    thanks
  2. MyEarsHurt New Member
    May 21, 2004
    Message Count:
    926
    Do you own the head unit yet? If not, then just buy it through crutchfield because they will walk you through the whole install step by step. They are awesome over there... But if you pay $130 for a head unit install you are getting taken bigtime.
  3. TenaciousD Founding Member
    Sep 15, 2001
    Message Count:
    324
    Tampa,Fl
    yeah, I already own the head unit.
  4. Mossberg Active Member
    Jul 22, 2003
    Message Count:
    1,216
    36
    ATL, Shawty
    130 is rape to install a headunit. It takes about 30 minutes tops.
  5. MerkurNut New Member
    Nov 20, 2003
    Message Count:
    20
    You all are missing the whole point. It isnt the CD player that is the "hard part". Depending on how they will "bypass" the mach 460amp is the key here. Either way that is about right for the price. I love how all of you are so cheap.
  6. TenaciousD Founding Member
    Sep 15, 2001
    Message Count:
    324
    Tampa,Fl
    I found this on another website, if it is right is does'nt sound to hard
    "if you remove the head unit and look into the cavity behind the radio on the right hand side, you should see a Ford FD-02 type factory radio connector clipped to the side of the console. buy yourself a compatible wiring harness and plug your deck into this input, which bypasses the factory amplifier system."
    as far as I can tell this is the harness
    http://www.partsexpress.com/pe/show...&St3=74734058&DS_ID=3&Product_ID=117730&DID=7
  7. MyEarsHurt New Member
    May 21, 2004
    Message Count:
    926
    Try that first man....its only 12 bucks if its wrong...that sure beats $130!
  8. TenaciousD Founding Member
    Sep 15, 2001
    Message Count:
    324
    Tampa,Fl
    i now have a new problem, the Metra rep sent me an email that said I need a 70-5510 harness for my exact car, every other place says I need a 70-5511. I emailed him asking if he made a mistake and he said no.
    This site seems to have everything needed for the install. I will let you know if it works
    http://www.thezeb.com/p-Metra-70-5510--Wiring-Harness-Adapter-106761.htm
    http://www.thezeb.com/p-Metra-88-00-9000--Mounting-Kit-106876.htm
    http://www.thezeb.com/p-Metra-86-5618-Ford-Radio-Removal-Tool-106861.htm
  9. eedwards New Member
    Apr 2, 2005
    Message Count:
    76
    NYS Albany area
    "I love how all of you are so cheap". - MerkurNut
    ahem.
  10. DMDyne New Member
    Apr 11, 2005
    Message Count:
    43
    Warren, Ohio
    The 5511 harness is not meant for the amplified system. The 5510 may be what we call an "add-a-head" harness at work(never checked the model number). With that one the factory amps will work and your volume will be high even at low levels on the radio. If you unplug the amps inside the radio housing like you said, you will probably need a 1770 harness and it will bypass the amps.
    My suggestion - get the 1770 and bypass the amps.
    Edit - Some installers don't like to mess with amplified systems. The 2 other guys I work with usually charge $65 to install into a Mach Mustang. If I'm available, they let me do it for the normal $40.
    I'm not sure where they are getting $190 at because the basic install is $40 and a "hardwire" is $25. 1 hardwire per amp = $100 + basic install = $140. Unless they are charging you for a 4 speaker installation as well which would be another $75....something doesn't add up there. I would suggest talking to the S&I manager at that Circuit City and not bothering with the sales staff or the installers.
  11. TenaciousD Founding Member
    Sep 15, 2001
    Message Count:
    324
    Tampa,Fl
    thanks alot for your help
Share This Page
