$2,000.00 budget.
Discussion in '2005 - 2009 Specific Tech' started by Houston94vert, Jun 9, 2008.
  1. Houston94vert Founding Member
    Apr 13, 2001
    Message Count:
    376
    Houston
    Found out my bonus isn't as big as I wanted...and we still want to redo the bathroom. So I've budgeted 2,000.00 for mods on the stang.
    Here's what I'm looking at:
    JLT cai and sct tuner: $549.00
    Pypes off road x-pipe: $160.00
    4:10 gears and installed: $500.00
    What else?? $791.00 to play with.
    I'm debating ... springs, style bar, under drive pullies, cams(but would need them installed and tuned), headers, short throw shift, throttle body, ...
    so really... 791 to play with...what else would you do?
  2. blacksheep06 New Member
    Feb 1, 2006
    Message Count:
    291
    Aluminum driveshaft is the next best go fast mod for under $791.
    You can get a spydershaft for about $500. 30 lb reduction in rotating mass. Do it with the gear install.
  3. whyask New Member
    Apr 4, 2005
    Message Count:
    766
    Sacramento
    slicks !
  4. PSYKOSTEVO Banned
    Apr 11, 2008
    Message Count:
    200
    UDP's look like another good mod. I'd stay away from the throttle body.
    And the Style bar always looks good on the convertibles, and you rarely see them. (They're pricey).
    You will be excited about the mods you already plan to buy because those make the biggest improvement.
  5. PSYKOSTEVO Banned
    Apr 11, 2008
    Message Count:
    200
    That much lighter?! Holy Cow!
  6. blacksheep06 New Member
    Feb 1, 2006
    Message Count:
    291
    Yea, close to it. It weighs 16.5 lbs compared to the 2 piece 45 lb stock shaft.
  7. V8JamesGT Member
    Jan 22, 2006
    Message Count:
    219
    18
    Eibach Lowering Springs - $225
    Tokico D-Spec Shocks/Struts - $510
    total - about $735
    *Will also need adjustable panhard arm bar... another $135
  8. FR-S8N Founding Member
    May 23, 2002
    Message Count:
    1,311
    McAllen, tx
    Are the gains from the spydershaft worth the money?
    How much improvement from it at the track?
  9. BLKNED Member
    Jan 27, 2008
    Message Count:
    67
    Hhhmmm, 30 lbs less rotating mass, sounds like that could help gas mileage too.:D Where would one get a spyder shaft from?
  10. DOHC Holliday New Member
    Mar 17, 2007
    Message Count:
    The All American Valley, CT
    I vote springs, shocks and struts.
  11. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    Florida
    Aluminum driveshaft is worth 2/10ths of a sec in the 1/4 typically.
  12. V8JamesGT Member
    Jan 22, 2006
    Message Count:
    219
    18
    You can get the Spydershaft at www.leonardracingproducts.com
    I've also heard that aluminum driveshafts are good for about 2/10 off quarter mile times
  13. ct07gt Member
    Feb 15, 2008
    Message Count:
    355
    What are you using your car for most? If you are drag racing, then the driveshaft sounds like the way to go. If you are on the street more, I would go with a suspension. A lot of one piece driveshafts require changing the pinion angle using an adjustable upper control arm if you ever plan on lowering the car.
  14. xxrequiemxx Member
    Aug 24, 2001
    Message Count:
    241
    Long Island, NY
    springs and shocks
Share This Page
