2.3L Perfomance?
Discussion in '2.3L (N/A & Turbo)' started by 302stang.93, Aug 7, 2009.
  1. 302stang.93 New Member
    Jan 17, 2008
    Message Count:
    12
    Houston, TX
    I just sold my 302 fox and got a 2.3L 91 hatch. What are some ways to get some power out of these motors?
  2. -Nick- New Member
    Aug 7, 2009
    Message Count:
    25
    to be honest...there are not too many cheap ways it can be done...
    because of its size....n/a is not a option
    these motors are not known for being anything great..
    but if you have to make it fast....turbo it
  3. Dr_EluSivE Founding Member
    Apr 24, 2002
    Message Count:
    2,387
    56
    Central Illinois
    You can get ~230hp with a turbo swap without much effort, More requires Headwork, bigger turbos, fuel, and other more expensive parts.
    Dr.
  4. wlabrum New Member
    Dec 1, 2008
    Message Count:
    26
    turbos are unnessacery but nice
    1. factory ford computer is JUNK timing curve is way off and has built in rev limeter 5500-5800
    2 intakes dont flow for nothing.
    3. compression is way to low
    4. cam is small
    I have an 88 lx that im pullin the efi off of, swaping in a carb sending unit and putting a carb on it. it all ready has a racer walsh header,w/ 2 1/4 back flow master,r/w adjustable cam gear and factory non roller tubo cam.
    head will be milled to aprox 9.6-1 compresision
    this is the 4th time i built this combo this is the only one that disapointed me
    the last 2 made over 160 flywheel horse power(there in my two brothers sand rails)
    they could of made more with morre than the factory 8.7 -1 ratio, but they go to mexico and get some crummy gas
    acording to eslinger this combo out to make 175 180 hp @ 7200 rpm
    its a small 4 cyl SPIN IT
  5. Red_LX I’m not much help unless you’re looking for porn?
    Aug 21, 1998
    Message Count:
    10,498
    78
    Morgantown, WV...where couches meet their doom
    Dude there is no ****ing way you made "over 160 hp" on an n/a 2.3 with a carb, header, adjustable cam gear, turbo cam and a little milling of the head. Or wait, did you say they made that much on the stock compression ratio? :bs:
  6. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,561
    66
    Antelope Valley, SoCal
    Yeah, I don't see an NA 88hp 2.3 gaining 72hp+ while keeping the stock longblock.....
    As far as suggestions for getting more power out of a 2.3NA, that's why we have a search function here; so you can find all the other times that same question was asked and answered.
  7. Rcdriver45 New Member
    Aug 2, 2009
    Message Count:
    20
    Italy TX
    what all can i buy for my 87 to boost power without having to buy a turbo or supercharger i already have a custom intake any sudgestions?
  8. SVO1 Lord of The somethin' somethin' somethin', hell, I
    Oct 25, 1999
    Message Count:
    4,598
    Lord of uh, hmm what was it again?
    Back in the day didn't Crovax have a bunch of stuff on his n/a and it still hardly made any power?
    For the cost involved finding a wrecked TC is much cheaper/easier....
  9. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,561
    66
    I would suggest using the search feature. This same exact question comes up at least once a week, so you should find lots of answers.
    His and all the other built pump gas 2.3NAs.
  10. Rcdriver45 New Member
    Aug 2, 2009
    Message Count:
    20
    Italy TX
    would the tornado fuel saver do anything to help?
  11. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,561
    66
    You're joking...........right? Please tell me you are.
  12. SVO1 Lord of The somethin' somethin' somethin', hell, I
    Oct 25, 1999
    Message Count:
    4,598
    It won't actually.
    We tested one and the only gain we found is if we left it out, then we dropped .00000000000001 off our drag times. why? Less weight in our wallet.
    Putting the tornado in added back the weight we lost, and caused us to gain back that .00000000000001
  13. Red_LX I’m not much help unless you’re looking for porn?
    Aug 21, 1998
    Message Count:
    10,498
    78
    I see you snuck back in here, Jay!
  14. Rcdriver45 New Member
    Aug 2, 2009
    Message Count:
    20
    Italy TX
    well dead gum! Ok im willin to try anything!
  15. SVO1 Lord of The somethin' somethin' somethin', hell, I
    Oct 25, 1999
    Message Count:
    4,598
    Put a 100 horse wet kit on it.
    Serious. It will be more fun and if setup right it will last a while.
    And yeah Garrett, I snuck back in :) Been a long time, but now that I'm unemployed I have all kinds of time!!!!
  16. Rcdriver45 New Member
    Aug 2, 2009
    Message Count:
    20
    Italy TX
    how much would a kit cost?
  17. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,561
    66
    Check with any performance shop of your choice. Summit Racing, Jegs, and $500 come to mind.
  18. Red_LX I’m not much help unless you’re looking for porn?
    Aug 21, 1998
    Message Count:
    10,498
    78
    And to add, that's $500 with an empty tank. Make sure there's a nitrous filling station somewhere near you.
  19. SVO1 Lord of The somethin' somethin' somethin', hell, I
    Oct 25, 1999
    Message Count:
    4,598
    and make sure you read up and understand the PROPER way to setup/tune for a Nitrous system.
    If you don't know about timing adjustments, spark plug heat ranges, how to read plugs etc, DO NOT put a kit on your car.
    And since I see it coming, Yes you can use a kit for a 5.0 or a generic kit, but you will have to do some modifying to make it work on your car.
Share This Page
