romans8:28
- Nov 25, 2004
- 35
- 0
- 0
TomServo92 said:Why should I blindly trust your recommendation when I have my own experience to rely on?
FYI, I asked my Mazda service advisor if using Mobil 1 at the first oil change was a problem and he said "No problem". In case your wondering, my Mazda has a 3.0L Duratec engine in it. I'm sure if you call your service advisor or the customer hotline they'll tell you exactly what I've been saying: "Use an oil that meets the specification outlined in the owners manual".
And you're absolutely right, you can lead horse to water....
I'm assuming the last part wasn't directed at me since I've never said anything about changing the oil at 500. The owners manual says to let it break in for the first 1,000 miles which would be earliest I would do anything regarding the motor oil.
EDIT: I re-read my earlier posts and I did allude to using synthetic within the first 1,000 miles. I meant at 1,000 miles as I stated above.
Look the original poster ask about switching to Mobil One at 500 miles.
I advised against it (and still do) for reasons similar to those expressed by Ford in the owners manual. The Engine should be allowed TO WEAR during the first 1000 miles (or more) in order to ensure the rings are properly seated.
Mobil one is very proud of "how wear is stopped dead in its tracks" by using the product. I can attest to that after tearing down many mobil one engines, and like I stated I use it in everything I own. cars, bikes, lawn equipment, you name it, its great stuff.
My whole point to this is you do not want to artificially stop engine wear prematurely or you will run the risk of lower than should have been power and aditional oil comsumption for the life if the car. Wait to 3000K miles and switch (or for Petes sake at least 1000)
Is this so hard to understand?
