30 lb injectors
Discussion in 'Fox 5.0 Tuning' started by airbag, Jun 16, 2006.
  1. airbag New Member
    Aug 17, 2005
    Message Count:
    55
    hebron, indiana
    i get a lot of different opinions. are these inj. too big, i have 30 lb. inj. with pro m meter calib. eddy 202 160's ,1.6 rr, cobra intake, 70 mm tb, x cam, dss shortblock, flows dumped, 255 pump. would i gain by going to 24lb inj, meter? does anyone else use x cam? dss recommended this cam (not sure if i agree). recommend opinions from people with experience (i didnt post this in talk). car dynoed 260 hp., 290 tq to the wheels, on a dynojet.
  2. Grn92LX Fidanza Man!
    Jan 14, 2001
    Message Count:
    6,627
    76
    New York
    30's are fine, perfect for that combo. No clue why dss recommended a dinosour X cam though. Any track times? How's the a/f on the dyno? How much timing you running?
  3. airbag New Member
    Aug 17, 2005
    Message Count:
    55
    hebron, indiana
    30lb injectors
    the best track time 13.50 @ 98 mph, 1.89 60 ft. a/f 12.5 to 1. timing was at 16 degrees the day at the track. had 275/50/15 mickey thompson drag radial. leaving the line at 5,000 rpm (5 speed) to keep motor in powerband for second gear. the car was hooking pretty good, very little tire spin off the line.
  4. Grn92LX Fidanza Man!
    Jan 14, 2001
    Message Count:
    6,627
    76
    New York
    Your dyno numbers are way low but more importantly, your track times are even worse!
    The a/f is a little rich but not enough to kill you that much. Timing looks fine.
    Do you have gears?
    Do you have a fuel pressure gauge you can watch while you are going WOT?
    Something is way off. You run less mph then my friends stock 90GT with only exhaust (stock gears too).
  5. airbag New Member
    Aug 17, 2005
    Message Count:
    55
    hebron, indiana
    30 lb
    have 373 gear, fuel pressure gauge is under hood.
  6. speadfreak New Member
    Oct 14, 2005
    Message Count:
    121
    there doesn't seem to be very many people looking at the "tuning" forum, does there?
  7. Grn92LX Fidanza Man!
    Jan 14, 2001
    Message Count:
    6,627
    76
    New York
    Not really but this wasn't really a tuning question.
    If it was a question about setting up a base tune with a PMS, tweecer or something there would be more responses.
  8. speadfreak New Member
    Oct 14, 2005
    Message Count:
    121
    I think it absolutely falls under tuning catagory. His numbers are way low for the parts that he has on his car. I think he is basically wanting to know if he needs to change his tune or if he just has a badly mismatched combination. If his tune is off and this is what is causing his lack of performance, I would think the tuning section is where one could find some answers. If the car is tuned well, somebody trying to help in the tuning section should be able to verify it for him........at that point he could go back to the tech section and ask what parts he could change to better his combo.
  9. Grn92LX Fidanza Man!
    Jan 14, 2001
    Message Count:
    6,627
    76
    New York
    His tune is a little rich but pretty close enough. It will be leaner on the street anyway due to the way the dyno loads the car vs how the street loads it.
    His issue looks mechanical.
    Did you check for proper pushrod length? Are the valve springs up to the task? Did you ever get a chance to watch what fuel pressure does through out a WOT pull?
  10. aleborjas New Member
    Sep 12, 2005
    Message Count:
    625
    hi looking to this post i have 30 pounders too with a 306 and 75mm pro-m maff, look my sig.do i need to change something?
  11. Grn92LX Fidanza Man!
    Jan 14, 2001
    Message Count:
    6,627
    76
    New York
  12. 88Stang331 New Member
    Mar 30, 2006
    Message Count:
    245
    Those numbers are deffinately low, seeing as i only have intake/heads, pro m 80mm, and i'm pushing 270/290 to the wheels
    TFS Stage 1 cam coming by next month =D trying to for 280-290rwhp and 300+rwtq
  13. payupsucka Member
    Sep 29, 2003
    Message Count:
    340
    Keeping it grimy in Fall river MA.
    i have the same intake as you a 306 tfs tw heads an e cam 70 mm tbody 24# injectors and a 73mm c&l maf and i dynoed 280 rwhp and 318 rwtq some thing is definetly off, it think you might have to much cam for the cobra intake and thats hurting you
  14. airbag New Member
    Aug 17, 2005
    Message Count:
    55
    hebron, indiana
    30 lb. inj.
    just got track heat intake in the mail. will post results as soon as i get to the dyno. thanks for the responses.
  15. Grn92LX Fidanza Man!
    Jan 14, 2001
    Message Count:
    6,627
    76
    New York
    You have a mechanical issue. I would look into the valvetrain. Are those the stock edelbrock valve springs? If so, get proper springs and install them properly. Did you check for proper pushrod length??
  16. 5spd GT "the 5.0 owns all"
    Aug 7, 2002
    Message Count:
    9,557
    76
    Arkansas
    Speaking from experience...I have 30lb injectors with a 75mm Pro-M TB on a daily driver.
    30lber's are "too much". I have a bit more aggressive setup than you...
    Hot crank starts (to much cranking fuel)...
    Surging idles...
    Rich smell...
    I should have went with 24lb injectors.
    30lbers would be just fine if you got it tuned on the dyno/chip...
    24's if you don't have the money or time to get a tune.
  17. 5spd GT "the 5.0 owns all"
    Aug 7, 2002
    Message Count:
    9,557
    76
    Arkansas
    Where are you shifting at?
  18. DMAN302 My mom says thanks for the pearl necklace.
    Nov 8, 2003
    Message Count:
    2,397
    98
    58
    windsor, Canada
    HP is down in my opinion because the heads are a tad to big and the cam is NOT a good match. Swap the cam to a custom and you'll see the number jump up significantly.
  19. Grn92LX Fidanza Man!
    Jan 14, 2001
    Message Count:
    6,627
    76
    New York
    The numbers are down b/c he has a mechanical issue that needs to be looked into. Those edelbrock heads are 170cc if I recall, not big at all.
  20. vikingpower New Member
    Dec 7, 2004
    Message Count:
    677
    CWU Ellensburg, WA
    I use 30lb injectors with this setup: TFS heads/cam, Typhoon intake, 75mm TB, BBK AFPR, C&L 73mm, BBK L/T's. I tuned it myself with a Nordskog digital fuel pressure guage and it runs awesome, still get ~25mpg going over the mountains to and from Seattle @70mph
Share This Page
