30 or 36 pound injectors
Discussion in '94-95 Tech' started by jromeo, Nov 9, 2009.
  1. jromeo New Member
    Mar 6, 2006
    Message Count:
    charleston sc.
    I have a 347 with AFR 185s , holly intake,70mm tb ,and a custom cam , 1 5/8 long tubes .The cam is good to about 6000 to 6400 rpms. I'm thinking the car should make 380 to 400 rwh.
  2. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,672
    68
    Acworth, GA
    30s will be fine.
    Kurt
  3. jromeo New Member
    Mar 6, 2006
    Message Count:
    charleston sc.
    will my 190 fuel pump be good or do I need to go bigger ?
  4. Grn92LX Fidanza Man!
    Jan 14, 2001
    Message Count:
    6,627
    76
    New York
    36's for sure. I had 100% maxed out 30's in my old 347..appx 400rwhp on a dynojet (made 370 on a Mustang dyno)
  5. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,672
    68
    Acworth, GA
    I got to go find that link for the injector table. 400rwhp should not max out a 30lb/hr injector.
    Kurt
  6. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,672
    68
    Acworth, GA
  7. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    I would like to mention :)
    All of those inj size programs I've seen relate to fwhp :eek:
    Most of us gearheads of today think in terms of rwhp
    Another thing is if you are runnin a centri charger .......
    those programs don't take into account the drain of the sc as well :(
    If you are gonna tune it
    I just can't see a reason not to have a bit of breathin room ;)
    Just somethin to think about :scratch:
    Grady
  8. Grn92LX Fidanza Man!
    Jan 14, 2001
    Message Count:
    6,627
    76
    New York
    I don't go by internet calculators, I go by real world tuning devices. I was seeing 96% duty cycle before the shift light came on with my PMS. Car NEEDED 42's but I decided to sell it before doing more changes.
  9. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,672
    68
    Acworth, GA
    When I was doing aprox 370rwhp, I was seeing about 78% duty cycle.
    Kurt
  10. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,672
    68
    Acworth, GA
    The one I posted was crank hp. Wheel hp is really immaterial when you are calculating injector size.
    Kurt
  11. Grn92LX Fidanza Man!
    Jan 14, 2001
    Message Count:
    6,627
    76
    New York
    Right..now the new owner of my car dynoed it on a MUSTANG dyno like I mentioned. So your 370 dynojet hp would be appx 400ish for my old car on a dynojet. What rpm were you turning? My old car would go to about 6,800-7,000.
  12. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,672
    68
    Acworth, GA
    Well, that would explain it I guess. I was doing that pull on a dynojet, and I make peak power at about 5500rpm. I let out on the dyno at about 6300rpm.
    Kurt
  13. nmcgrawj Advanced Member
    Sep 28, 2003
    Message Count:
    3,674
    66
    Indianapolis, IN
    I'd rather have too much injector that i can tune down then have not enough injector that i have to up the fuel pressure for to squeek by.
    I've seen some h/c/i 302s run 30s....
  14. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    How do you see it that way when the op said he was lookin for 400rwhp
    I mean ... That equates to about 475 fwhp
    You gotta tie one to the other
    If I am missing something here :scratch:
    I guess I need someone to enlighten me :shrug:
    Grady
  15. Black95GTS Active Member
    Jan 8, 2004
    Message Count:
    1,658
    36
    Marlborough, MA
    36s, if you can find them. I understand they are hard to come by these days. The standard 42 pound injectors and 90mm LMAF would work fine in this situation, especially if you don't want to crank up the fuel pressure past the stock setting. If your cam can make power to 6400 you will be shifting around 7000. Another advantage of the LMAF is that a lot of people have experience with it so you'll find good support if you self-tune. You'll also want the 255 in tank pump.
    Your 70mm TB is likely too small. If you have it already keep it, but if you have the chance, step up to at least a 75mm unit. Not sure if you have to modify the Holley intake to accept that size, but you'll likely be using the trickflow adapter elbow and thats setup for 75mm anyway. Don't worry, it won't "hurt your low-end grunt" WTF that means. [hides from keyboard dragracers]
    Adam
Share This Page
