I was fitting together my motor and found that the bearings eagle wants me to use do not fit. The crank manufacturer said to use stock 302 bearings. Has anybody run into this. Thanks
I threw my bearing boxes away or else I would go check the part numbers. They were marked STD for standard size, but I had Scat rods...not sure if Eagle is different in size although I would assume they are the same.
