4:10 guys????
Zora
113
Did you replace the cross shaft in the rear end so the 4:10 gears would fit? Also were you able to reuse the factory rear cover? What fluids?
Thanks
No reason to replace the shaft until you install 4.56 gears. The only difference is the shaft has a flat section to clear the thicker ring gear. The stock rear cover will work with all the gears. I use Royal Purple synthetic oil. But any synthetic is fine.
Shelby cars tried to tell me I needed to replace the cross shaft if I went to 4:10 or bigger. I told them thats the first I had ever heard of that. Their catalog even states it.
Royal Purple..what weight? Factory weight?
Thanks
I used the factory weight oil in mine. I lost about 2 MPG on the freeway but my mileage increased around town. I lost roughly 1 MPG city and highway combined. To me, the 4.10's are worth the loss in mileage.
