4.6 swap question
Discussion in 'SN95 4.6 Talk' started by kswitch, Mar 4, 2008.
  1. kswitch New Member
    Aug 19, 2004
    Message Count:
    11
    Hey i was just wondering if u are able to swap a 99-04 motor into a 98 gt without that much modification other than tranny,mounts, n maybe exhaust? If anyone has done this or something related because it was a thought that crossed my mind :) thx for the help you guys appreciate it :)
  2. 1990Coupe Founding Member
    Mar 11, 2002
    Message Count:
    1,255
    109
    63
    I'm far from someone who know's alot about the newer models (i'm a fox guy trolling the 4.6 forums cuz i wanna get one :D ) But im pretty sure is the exact same engine with the exception of the heads, cam, and intake.. Newer 99-04 cars have the "performance improvement" heads, cam and intake.. vs. the Non P.I. cars of the 96-98 era.
  3. rw98gt New Member
    Jun 26, 2006
    Message Count:
    69
    hey, don't change the whole motor do a pi head and intake swap, you will gain more power than a stock pi motor. this is because the 96-98 4.6's are 9.3:1 compression, the 99-04 are 9.7:1 compression, with the pi head and intake swap on a 96-98 4.6 the compression is 10.6:1. the block and heads squeez more compression w/the swap producing more power. i am in the process of doing this with my 98gt however i am porting, camming with springs. my motor will be putting out 400hp w/out the supercharger. that's awsome if your motor is running without issues just do the swap you will not regret it and w/a little extra $ you can make some serious power. good luck & hope this gives you something to think about...
  4. CobraRed_96_GT Active Member
    May 20, 2006
    Message Count:
    1,642
    36
    hope you're talking about using spray too then, otherwise you're blowing smoke
  5. rugster New Member
    Aug 31, 2004
    Message Count:
    162
    it was pretty easy, I did it without much trouble.
Share This Page
