2003 mustang 4R70W
8,500 miles
Removed bottom line from radiator and pumped a few quarts in a pan.
Removed the trans pan, and filter
Removed the 4 plactic electrical connecters from main control
Removed main control
Removed seperator gaskets and plate
Drilled holes in seperator plate to J-mod spec MILD
installed seperator plate w/ new gaskets
removed lower spring from 1-2 acc.
removed upper and lower spring from 2-3 acc
reinstalled main control [90in/lbs in order]
cliped electrical conector on, and filter
replaced pan
added a B&M trans cooler: lower trans line goes into radiator then upper line goes to cooler, cooler then is connected to upper trans line. Leaks a little but i can remedy that.
Filled with mercon V fluid, checked fluid at least 20 times as transmission was heating up.
Decided to let a little out in case of an overfill, disconnected the trans line and pumped a little in a pan. When pumping out of transmission the fluid comes out rather slowly.
