5.0 Fox Help
Discussion in 'Fox 5.0 Mustang Tech' started by 89powerhouse, Nov 4, 2009.
  1. 89powerhouse New Member
    Oct 27, 2009
    Message Count:
    I swapped a 4 cylinder to a 5.0. I eliminated power steering and ac completly. Not even running eliminator pullies. I need an idea on how to run the belt because of the reverse rotation water pump. Can someone please help me out?
  2. liljoe07 New Member
    Feb 18, 2009
    Message Count:
    1,033
    Cartersville,Ga
    Only way with the stock tensioner and bracketry( is that a word...LOL) is tweek the stock tensioner so it applies pressure up instead of dowm. The other way is to use a March Alternator bracket setup.
    If not that way, you will have to have a A/C eliminator setup.
    Sponsored Ad
  3. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,649
    9
    78
    Massachusetts
    Standard rotation water pump as well
    [IMG]
  4. tannerc91gt Advanced Member
    Mar 29, 2009
    Message Count:
    3,933
    18
    68
    Indiana
    Ya it's not like a water pumps terribly expensive why did you buy a reverse in the first place?
  5. 89powerhouse New Member
    Oct 27, 2009
    Message Count:
    How do you "tweek" the tensioner to do that?
  6. liljoe07 New Member
    Feb 18, 2009
    Message Count:
    1,033
    Cartersville,Ga
    Not a must. You can use the Reverse Rotation pump, with a fliped tensioner. Looks like hell, but it works. Just have to keep the flat side of the belt against the Water Pump pulley.
    Nevermind 5L5, I see what you meant. Your just saying its another option. And your right.
  7. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,649
    9
    78
    Massachusetts
    Yeah, i meant it as an alternative option. Looks clean IMHO
Share This Page
