5.0 ho distributor on late model block
That is exaclty what it is suppose to do if you hook it up to a manifold vacuum souce. It makes the engine have a smoother idle by advancing the timing. The more gas you give it, the less vaccuum it will have and therefore less of an advance on the timing. If you hook it up to a ported vacuum source, the more gas you give it, the more it will advance the timing. At idle, it will not advance the timing at all.
