86 heads E6SE
Discussion in 'Classic Mustangs' started by mnbf, Sep 15, 2004.
  1. D.Hearne Banned
    Sep 30, 2000
    Message Count:
    12,124
    south louisiana
    Yes here too. :nice:
  2. mnbf New Member
    Aug 15, 2003
    Message Count:
    207
    Canada,Saskatoon
    cool
    Alright thanks for all the help guys
  3. clevorstroker New Member
    Nov 1, 2010
    Message Count:
    i bought a 89crown vic from a guy that has e7te stamped on the block that is equipped with roller lifters 302 firing order, forged small dish 0 valve relief pistons, and efi system. the original factory heads were '86 stamping that are heart shaped combustion chambers which aka quenched, or closed for higher compression, which is only meant for a raised compression ratio over the 87 heads which were bigger chambered, and also this bigger chamber created lower compression and in all reality equals less power.BUT the 87s had bigger exhaust runners with big chambers thats good for blower or turbo i think the small combustion chamber with smaller exhaust runners in the quenched chambered heads made for better torque specs. the e7s were more for horsepower i would guess
  4. woodsnake Member
    Jan 16, 2007
    Message Count:
    999
    18
    Out of Africa, back in Idaho
    Did anybody bother to ask mom how fast she wants to go?
  5. D.Hearne Banned
    Sep 30, 2000
    Message Count:
    12,124
    south louisiana
    Talk about raising the dead, this thread's 6 years old.
  6. D.Hearne Banned
    Sep 30, 2000
    Message Count:
    12,124
    south louisiana
    The E6 head's chambers look smaller, but they're also deeper, with 4 more cc's volume than the E7 heads. Looks can be deceiving. And the exhaust runners are the same for both. The reason the E7 heads make more power on top is due to the chamber shape, the valves aren't shrouded by the chamber walls like they are in the E6 heads. To illustrate what I mean by deeper chambers, pull an intake (or exhaust) valve from each casting and you'll find that the E6 valve is shorter by about 1/8"
  7. jonfor New Member
    Apr 20, 2009
    Message Count:
    60
    Columbus, GA
    I have an ’86 mustang engine in my car with those heads and a carburetor-headers-duraspark and am relatively pleased with the performance. The car only has a 3.0/1 peg-leg rear axle and will easily pull a greased string from a cat’s ass. Results are not so good with a dry string.
  8. D.Hearne Banned
    Sep 30, 2000
    Message Count:
    12,124
    south louisiana
    Your results are due to the E6 heads producing more bottomend torque, combined with the 3 to 1 rear gears. The 86 HO Stang actually did produce better 1/4 mile times over the 87 due to this.
Share This Page
