#89-332 finally dyno'd :)
Discussion in 'Saleen' started by BoostedmaxPSI, Nov 13, 2005.
  1. BoostedmaxPSI New Member
    Apr 30, 2003
    Message Count:
    292
    Keller, TX
    Thanks for the replies and help.
    So what suggestions can you guys offer me to get to 350?
    Also, I seem to keep having a problem blowing the PCV out of the lower intake everytime I get into the boost. What can help keep this from happening?
    Would you mind listing your combo that got you to 400, I'm looking for a good roadmap to follow :)
    Thanks
    Frank
  2. saleen065 New Member
    Oct 31, 2004
    Message Count:
    655
    Douglasville, GA.
    power pipe and a 9lbs of boost with minimum 30lb injectors and 75mm MAF should get you close to 400rwhp.
  3. saleenster Founding Member
    Aug 19, 2002
    Message Count:
    2,636
    46
    Vancouver, WA
    S-Trim, Powerpipe, 38 lb injectors, 255 fuel pump and a good tune. The blower is only seeing 10 lbs with the stock pulley and power pipe. There is alot more in it, but I am running out of fuel, so this is enough for now. I need an inline pump then I can change pulleys and increase the tune and timing, and 450~475 rwhp should be within reach:D
    The A trim is going to be a challenge. I had an A trim on a past Saleen which made 333 rwhp with GT40 iron heads, Saleen upper and lower, and motorsport E cam. Nothing was ported so good port work might get you close to that number. Good luck Frank.
  4. BoostedmaxPSI New Member
    Apr 30, 2003
    Message Count:
    292
    Keller, TX
    OK, I'm going to take it to a local Ford performance shop and see what they can do with the existing A trim.
    I already have a 255lph in the tank and a set of 42lbr's. I know the 42's are way more then I need or will use. So, I'm looking to trade them for something that can help my combo to get me to 350hp at the wheels.
    Anyone with old parts?
    FS
  5. saleen065 New Member
    Oct 31, 2004
    Message Count:
    655
    Douglasville, GA.
    Want to sell the 42's?
  6. BoostedmaxPSI New Member
    Apr 30, 2003
    Message Count:
    292
    Keller, TX
    Sure if the fuel rails go with it. PM me an offer.
    Then I can pick up Saleenster's MAF and 24's :)
  7. saleenster Founding Member
    Aug 19, 2002
    Message Count:
    2,636
    46
    Vancouver, WA
    That would work good with your set up.
  8. Quazimodo New Member
    Sep 21, 2004
    Message Count:
    60
    With an A Trim I got 10 lbs out of it with a smaller pulley. I forgot which one though . I ran an A trim 10 years ago and went as quick a 11.3 with it.:)
  9. BoostedmaxPSI New Member
    Apr 30, 2003
    Message Count:
    292
    Keller, TX
    PM me where you want the money order to go to and who to make it out to unless you take PayPal, then we could do this tonight :)
Share This Page
