93 cobra 5 lug
Discussion in 'Fox 5.0 Talk' started by Project 77, Nov 20, 2007.
  1. Project 77 Founding Member
    Jun 30, 2002
    Message Count:
    548
    Bernville PA
    What do i need for a 5 lug disc brake swap on a 93 cobra??? these wheels ae such an oddball size and I want to upgrade
  2. BlownFiveLiter have car, will race....wait, it doesn't run
    Oct 23, 2004
    Message Count:
    5,458
    20
    88
    Chicagoland
    Same as any other Fox. 94+ spindles, hubs, brakes, and your choice of Ranger, Aerostar, Mustang, or aftermarket axles.
  3. Kabuki_notch Founding Member
    Nov 19, 2001
    Message Count:
    459
    28
    Rochester, NY
    for the rears you will also wants North Race brackets for the rear disc conversion http://www.northracecars.com/catalog/brakes/brakes.htm I am assuming you would want to keep it rear disc? I swapped the axles on my cobra with ranger axles. As stated above the front will be the same as other foxes
  4. Project 77 Founding Member
    Jun 30, 2002
    Message Count:
    548
    Bernville PA
    the only thing that sucks is the rear of this car has new mossr axles. Thanks for the info. Just pisses me of nobody makes a repro wheel that has the same offset and backspacing to fit the 4 lug cobra rear discs. (not that I have found anyway)
  5. Shakerhood Active Member
    Oct 29, 2004
    Message Count:
    2,567
    48
    Ohio
    I am pretty sure I read in the Tire and Wheel Section of the Corral that they were making custom backspaced 93 Cobra Wheels in 5 Lug.
Share This Page
