99 cobra problems
Discussion in 'SVT Forum' started by twiztid5.0, Dec 7, 2007.
  1. twiztid5.0 New Member
    Jan 22, 2007
    Message Count:
    Need some help quickgot a 99 cobra that hesitates bad from idle to 2300 rpms.Gets better once car warms up i have changed tha plugs,fuel filter,and the upstream o2s plus cleaned the maf and the intake runners.Keeps throwing the p1130 and the p0174 code.Ford told me there was a air/fuel senser on the car but cant locate it.
  2. twiztid5.0 New Member
    Jan 22, 2007
    Message Count:
    heres the update removed plugs to check and bank 1 plugs are firing but bank 2's plugs were covered in carbon .Can any body give me a explanation what can cause this?What can cause the side to side diff.
  3. Price1 New Member
    May 11, 2003
    Message Count:
    108
    My guess is a bad O2 sensor on that side. See this for P1130
    http://fordfuelinjection.com/files/HEGO_OBDII.pdf
    Also see this for P0174: http://affordableserviceonline.com/GM/LMvan/Pcodes/gmdtc_p0174.htm
    Search is your friend. Just google on "dtc Pxxxx" and you'll be amazed at what comes up.
    They could very well be related. The O2 sensor is what they were referring to as the A/F sensor. It would be the first one upstream from the cat. The rears really don't do much. Replace both upstreams just to be on the safe side. Oh, and use the Ford units rather than generic Bosch replacements. Hope this helps.
    Good luck....
  4. BeaconHillBarry New Member
    Dec 10, 2007
    Message Count:
    14
    interesting! mine's been having the same problem... just haven't had good enough weather to work on it.
Share This Page
