A/C duct problem
Discussion in 'Fox 5.0 Talk' started by BlackNBlue91, Oct 18, 2009.
  1. BlackNBlue91 New Member
    Mar 31, 2009
    Message Count:
    I have air coming out of the floor ducts and the defrost ducts, but nothing out of the dash vents. Any thoughts?
  2. ID89GT Active Member
    May 26, 2008
    Message Count:
    1,532
    38
    Check to make sure you vacuum canister is still hooked up. Or you could have a vacuum leak somewhere under the dash like me and need to take the whole dash off to fix it more than likely..
  3. 7upstang91 Member
    May 30, 2008
    Message Count:
    742
    Just a vaccum line snapped near the canister. They get old and brittle and tend to break.
  4. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,442
    11
    88
    Diagrams courtesy of Tmoss & Stang&2birds
    [IMG]
    See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
    (website host) for help on 86-95 5.0 Mustang wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
    Ignition switch wiring
    Complete computer, actuator & sensor wiring diagram for 88-91 5.0 Mass Air Mustangs
    Complete computer, actuator & sensor wiring diagram for 91-93 5.0 Mass Air Mustangs
    http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
    Complete computer, actuator & sensor wiring diagram for 94-95 5.0 Mass Air Mustangs
    http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
    Vacuum diagram 89-93 Mustangs
    HVAC vacuum diagram
    TFI module differences & pinout
    Fuse box layout
  5. BlackNBlue91 New Member
    Mar 31, 2009
    Message Count:
    Where is the canister you refer to on a fox? Do I access it by taking the dash off?
  6. 7upstang91 Member
    May 30, 2008
    Message Count:
    742
    No it is on the left side firewall when you are facing the car. Just behind the Trottle body but attached to the firewall. Look for a little black vaccum line.
  7. 7upstang91 Member
    May 30, 2008
    Message Count:
    742
    Should be a silver color. Or mine is anyway. The tiny black hose will be running through the firewall as well.
Share This Page
