No, as a matter of fact, I haven't. And never would spend that much for an exhaust system. I'lll stick with my locally bent system and home made exhaust "equalizer" pipe. As for the intake, yea, I spent way over that for the six pack setup I'm running on my 331, but the power factor wasn't a part of my decision to buy it, rather it was to have something different along with the awesome sound three carbs make when you nail the gas. The intake I ran before with the Canfields on a 306 shortblock was a used Vic Jr, and a used Holley 650 dp carb that I milled the choke assembly off myself and blended the airhorn after removing the choke. I acquired it used with a 66 Stang parts car ( basically free) spent $100 for a new base plate & $30 for a kit, and another $15 or so for a new fuel line for it. Worked just as well as a $600 setup would have, for 1/2 the price. Sold it a couple months ago along with the Vic Jr for $250, so I was basically out $50 after all was said and done. The Canfields were also a bargain for the $1050 I spent for them.87gn2 said:8hp for $100? I guess you never spent $300+ for a dual exhaust system on a stock V8 that might have netted you 10-15hp??? Or 600 for an intake manifold and carb that might have netted 25hp?
Cbarton said:While there is truth in what you say about advertising dollars making the mags favor certain parts, I don't believe they would alter dyno results to make a loser a winner because they spend more on ads. That is reaching a little. Hell, that's reaching a LOT.
I consider average readings VERY important as an alternative to peak. Sometimes I see average from 4,000 to 6,000 RPM, sometimes I see them as in this case from 2,500 to 6,000. The former is a good indication of output in racing conditions, but how much power an engine makes below 3,500 is VERY important to folks like me who want to be able to cruise around and mellow out sometimes. I'd hate to HAVE to leave every light at 4,000+ RPMs, think of all the negative LE attention that would garnerRoute666 said:Now 25 is something. 26 less torque for the AFRs is also something. The average shows 9 HP and TQ over the Canfields, not exactly worlds apart.
Edbert said:I consider average readings VERY important as an alternative to peak. Sometimes I see average from 4,000 to 6,000 RPM, sometimes I see them as in this case from 2,500 to 6,000. The former is a good indication of output in racing conditions, but how much power an engine makes below 3,500 is VERY important to folks like me who want to be able to cruise around and mellow out sometimes. I'd hate to HAVE to leave every light at 4,000+ RPMs, think of all the negative LE attention that would garner
