AFR vs ECT
Discussion in '94-95 5.0 Tuning' started by toyman, Jun 16, 2009.
  1. toyman Active Member
    Jul 20, 2007
    Message Count:
    1,259
    38
    Whenever I change the AFR to 14.7 at idle and low load the ECT increases to about 220* vs 195* at AFR 14.0. Ambiant air temp is about 80*. Does this make sense? Low fan is on at 190* and high at 220*. I know that the leaner burn will be hotter but this seems out of whack. I'm using 94 octane fuel if that makes a difference. Not certain if timing is also a variable in this equation.
  2. shoua50 New Member
    Feb 19, 2010
    Message Count:
    17
    too lean at idle for boosted combo. set afr at 13.5 at idle and 14.5 while cruising. u get no heat dissapation at idle, that's why ect is 220, while cruising u can run 14.5 afr due to air flow to help control temp.
Share This Page
