ALLIGNMENT ?
HKYBUM33
I just got my longtubes put on my 99 GT vert but my front spring were taken off for the install, I have a 2" drop in the front with H&R supersport springs and MM CC plates, do I have to get ANOTHER allignment done ?
HKYBRUm
..Tie rods control your front wheel toe in/out effecting steering mostly.
..Struts will effect caster and camber positive/negative effecting tire wear mostly. You can easily drive with the camber/caster all messed up, it will show itself by excessive tire wear. The toe in/out is going be immediately noticed in the car pull pushing one way or the other.
Quick ?, I put my springs on a little while ago and still havent gotten an alignment. Im planning on getting one this week though. On thursday my nitto dr's will be here and I want to get them mounted asap, will a bad alignment mess up the rear tires too, or just the front? There doesnt appear to be any wear on the rear tires right now, just the fronts.
