Aluminum Master Cylinder - Manual Disks?
Discussion in 'Classic Mustangs' started by phutch11, Nov 15, 2009.
  1. phutch11 New Member
    Nov 14, 2005
    Message Count:
    329
    I've got Scarebird disk brakes on my 66 with drums out back. I need to move to a new master cylinder as my current one is a dual for a 1967 with drums all around.
    I know that the 74 Maverick is what is recommended, but I'd like to move away from the heavy cast iron MC and to a modern aluminum MC with a plastic reservoir.
    I've heard of people running a 1993 Ranger master or one from a Cobra - 1995, I think.
    The Cobra is way too much - $150; and the Ranger's diameter is close, but not dead on.
    Anyone with manual disks running a modern aluminum MC?
    Thanks
  2. Grabber70Mach Member
    Jul 7, 2003
    Message Count:
    304
    Indian Head, MD
    If I remember correctly look at a 94-95 5.0 mustang. I think that is the one I used when I did my conversion.
  3. phutch11 New Member
    Nov 14, 2005
    Message Count:
    329
    Pedal feel good?
    Good travel and ability to modulate?
    Posted via Mobile Device
  4. wicked93gs New Member
    Sep 30, 2006
    Message Count:
    565
    Nashville TN
    I have an aluminum dual bowl master...I used one from an '84 t-bird....some of these are aluminum and some are cast iron...remanned it was $25 at autozone...however the ports are on the engine side so it would require new lines...but mine is still the old style without the plastic resevoir(I hate how cheap they look)
    p.s. 7/8" bore so its great for manual brakes
  5. Vinyl66 Member
    Mar 21, 2004
    Message Count:
    399
    I have Wilwood 4 wheel discs on my '66 and run the Ford D9AZ-2140-A master cylinder. It is all aluminum (no plastic) so it looks good in the engine compartment, has a 1" bore, and is much lighter than the big cast iron ones.
  6. phutch11 New Member
    Nov 14, 2005
    Message Count:
    329
    Just for the record, I found data that a MC from a 1993 Dodge Spirit would work- it doesn't work.
    Just going with the old heavy 74 Maverick.
  7. Grabber70Mach Member
    Jul 7, 2003
    Message Count:
    304
    Indian Head, MD
    Sorry for the late reply, my setup is PDB and I just noticed that yours is manual. Mine works fine, but not really sure how it would work in a MDB setup.
  8. JohnnyK81 New Member
    Sep 17, 2007
    Message Count:
    I'm in the same boat, except I Have power discs as well. I currently have the SN95 master on there, but it has a rock hard pedal feel.. It's 1 1/16 I believe, wondering if I should step it down to a 15/16 or so?
  9. Rusty67 Well-Known Member
    Dec 3, 2002
    Message Count:
    3,360
    56
    SB, CA
    7/8 and 15/16 are the sizes I'm use to seeing in a manual brake setup.
  10. JohnnyK81 New Member
    Sep 17, 2007
    Message Count:
    Agreed. So I wonder why my 1 1/16 is far too stiff with a power booster. And if stepping down to a 15/16 will make my pedal hit the floor.
  11. Rusty67 Well-Known Member
    Dec 3, 2002
    Message Count:
    3,360
    56
    SB, CA
    It should make your pedal effort easier but if you are having stiffness issues with the current setup, I would see if you have an issue with your booster as it is. Is the pedal just as stiff without the boosters assistance as it is with assistance ?
  12. JohnnyK81 New Member
    Sep 17, 2007
    Message Count:
    Pedal does sink a bit when the car is started. As well it seems to hold pressure (it's a brand new remanned). However, what I found odd, is while driving on some gravel (Car isn't road worthy yet) I was testing the brakes. If I hammered on this brick of a pedal, the fronts locked, but the rears wouldn't, even with the adjust. prop valve all the way to the rear, but they bled fine, so I"m stumped.
  13. Rusty67 Well-Known Member
    Dec 3, 2002
    Message Count:
    3,360
    56
    SB, CA
    Do you have drums in the rear ? Is there a residual pressure valve in the drum circuit ? Is it put in the proper direction ?
  14. JohnnyK81 New Member
    Sep 17, 2007
    Message Count:
    Nah, SN95 discs in the rear, stock 68's up front. SN95 master, plumbed correctly (front to rear, etc), going into a simple Tee for the fronts. Rears go directly from the M/C to the prop valve. As I said, I'm stumped. Vacuum is good.
  15. Rusty67 Well-Known Member
    Dec 3, 2002
    Message Count:
    3,360
    56
    SB, CA
    Now that we have completely hijacked the thread....
    What power booster are you using ?
    Actually, make another thread for this... it should really be on its own.
  16. JohnnyK81 New Member
    Sep 17, 2007
    Message Count:
    Yeeeeeah, I apologize for that. But it's still helpful to the OP. ;) Remanned Bendix. I was alternating between 10 and 15" vacuum.
  17. phutch11 New Member
    Nov 14, 2005
    Message Count:
    329
    No worries I,m all set with a vast iron boat anchor of a MC.
    You may need a residual pressure valve in the rear circuit to keep enough fluid back there to get those rear discs to work.
    What pedal are you using?
  18. JohnnyK81 New Member
    Sep 17, 2007
    Message Count:
    Never heard of anyone using a residual valve on rear discs, unless they are higher than the M/C or some such.. Using the correct power pedal. I guess all I can do is change the M/C and see what kind of difference it makes. Or test the pressure at each caliper, but I really don't feel like buying another tool. haha
    Don't suppose there is an online calculator, or anyone knows the equation of piston bore to m/c bore to pedal travel?
  19. 67coupestang Founding Member
    May 31, 2002
    Message Count:
    497
    ill chime in with my 98 explorer m/c im running brakes from a 73 on both ends, pedal feel is firm but not bad, but im not sure i would like it if the car was an automatic. the only problems i remember were finding adapters to the metric bungs
  20. zm830101 New Member
    May 17, 2005
    Message Count:
    117
    warner robins, ga
    are you using power brakes as well?
Share This Page
