Another piston Q
Discussion in '2.3L (N/A & Turbo)' started by Keasbey, Jun 20, 2005.
  1. Keasbey New Member
    Jun 12, 2003
    Message Count:
    928
  2. i4power Founding Member
    Jan 11, 2002
    Message Count:
    1,096
    I dunno if you should use flat top pistons...wouldn't those create higher compression?
  3. Anlushac11 Founding Member
    Feb 17, 2001
    Message Count:
    2,270
    Flat top forged pistons were stock on the 79-81 carb turbo 2.3L's.
    You would need to check the compression height. Dished pistons would be better but you could drop the compression a bit by opeing up the compression chamber and unshrouding the valves.
  4. freakintiger New Member
    Apr 9, 2004
    Message Count:
    310
    I've always been under the impression that you use dished pistons in boost applications...
  5. Anlushac11 Founding Member
    Feb 17, 2001
    Message Count:
    2,270
    Ideally you want to lower the compression ratio to improve volumetric cylinder filling.
    I think you can get forged dish turbo pistons from Race Walsh but I dont have a current catalog.
  6. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Just for reference, you can get stock replacement forged turbo pistons from autozone for like 40 bux each...maybe 35. They are speed-pro brand.
Share This Page
