Anyone with experience with '88ish Bronco II's?
Discussion in 'Fox 5.0 Talk' started by 85_SS_302_Coupe, Feb 23, 2007.
  1. 85_SS_302_Coupe it sucks (I know) to be on the receiving end
    Nov 11, 2003
    Message Count:
    7,277
    125
    113
    Northern KY
    I might be trading my beater '95 GMC Suckoma for a decently clean '88 Bronco II. It's got a lot of miles but drives really smooth all considering. The body has the typical fender/bottom door rust but it's 4wd and a 5 speed (i should probably make note that my Suckoma is more or less a good running wadded up chunk of metal that's been wrecked several times but yet runs like a top).
    So anyways, are there any huge demons about the Bronco IIs? Any reason i should stay away from it?
  2. BK_CAULEY it's built for speed not longevity, woman
    Dec 26, 2006
    Message Count:
    1,760
    36
    Thomasville, ga
    shifter
    yea the stock 5 speed shifter is a P.O.S i had one when i was 16 and the shifter could spin around in circles and because of its shape when you go to up-shift it would spin around and you will slam your knuckles into the dash. pretty anoying. and i have seen other trucks do it as well like rangers of the same year so i guess it was a tranny default for those years but other than that it was tough as hell. 16yr old + bronco II - any experience driving = trashed vehhicle.
  3. mustangjoe87 Member
    Jul 23, 2004
    Message Count:
    385
    Harrison Twp., Michigan
    what motor, I had the 2.9 V6 and it was a piece of crap
  4. 85_SS_302_Coupe it sucks (I know) to be on the receiving end
    Nov 11, 2003
    Message Count:
    7,277
    125
    113
    Northern KY
    Ok guys....we're not comparing the Bronco to the Mustang here...lol
    Does the thing run decent? Is the 4wd capable?
  5. mattmcdan Member
    Apr 20, 2006
    Message Count:
    189
    18
    Okeechobee, Florida
    I agree the 2.9 was a big POS along with the rotten 5 speeds they used behind them.
  6. 85_SS_302_Coupe it sucks (I know) to be on the receiving end
    Nov 11, 2003
    Message Count:
    7,277
    125
    113
    Northern KY
    That's fantastic....i just got a 2.9/5 speed :rlaugh:
    Here goes nothin :lol:
  7. iwashmycar New Member
    Apr 8, 2004
    Message Count:
    1,366
    9
    Columbus, Ohio
    just see what happens. i want a beater bronco II :(
  8. 85_SS_302_Coupe it sucks (I know) to be on the receiving end
    Nov 11, 2003
    Message Count:
    7,277
    125
    113
    Northern KY
    Well my thoughts on it is, i drove it and it ran like a bat out of hell, and it's got a little over 100k miles on it, so if it were a total piece of crap i don't think it would've made it that far. Plus a lot of the parts are Ranger swap parts so it'll be easy to fix.
  9. kck6894 New Member
    Mar 18, 2004
    Message Count:
    4,277
    Paradise
    Make sure you don't let it get anywhere close to hot! They have REALLY BAD head problems on all the 2.8/2.9/4.0L's. I'm not sure why but the tend to crack down through the spark plug holes. The 5spds in them are definitely junk! They had bad problems with the read drive shafts too. Other than that they’re not a bad rig!
  10. StangerT New Member
    Jan 21, 2004
    Message Count:
    9
    Boise, ID
    Not to :dead: about the obvious, but I had a good buddy of mine get killed in one driving on the freeway, guess a car changed lanes without looking so apparently he swerved lost control and it flipped multiple times... They are really unstable with that short wheel base, so don't do any crazy stunts with it... :nono:
  11. carbed87 New Member
    Jun 5, 2005
    Message Count:
    367
    denver co
    B-dueces are awsome, they're arguably the cheapest 4wd vehicle on the market right now. a BUNCH (like 5) of my friends used to have em, all with the 2.9 and i think 3 with the 5spd (i may be wrong though) and between the 5 of them there really wasn't all that many reliability issues. sure they sucked gas and occasionally ran rough, but my buddies thrashed them and they just kept asking for more.
  12. 85_SS_302_Coupe it sucks (I know) to be on the receiving end
    Nov 11, 2003
    Message Count:
    7,277
    125
    113
    Northern KY
    Well thanks for the input....i really don't plan on keeping it for a long long time though. The thing was that i've got this truck that's beat to hell and back and even though it ran like a champ, i got tired of driving a wrecked and beat up truck. So, i'll probably put this on the local for sale forums and see what i can sell it or trade it for and drive it in the meantime.
  13. ryan218 In just 10 years, I'll be old enough to drive!!!!
    Dec 29, 2005
    Message Count:
    214
    27
    38
    columbus ohio
    My dad had one...88 Brocno II and it was bright orange lol.... 2.9 V6 5 speed....
    4WD...it was a good for...daily driving, towing stuff...and beating the **** out of......i really liked that truck....if i can get the scanner to work ill upload a picture.....
    292,xxx miles later and a blown to pieces rear end :rolleyes:..he traded it in on the ranger....
  14. mustangjoe87 Member
    Jul 23, 2004
    Message Count:
    385
    Im not being completely fair, the previous owner blew a head gasket and it never ran correctly for me.
  15. Mustang78 New Member
    Feb 8, 2006
    Message Count:
    494
    Aberdeen, WA
    i've owned 2, and delt with a few more, my brother cracked the ring gear doing a burnout from gravel to pavement..my dad broke the front halfshaft(they're weak), the guages are known for being..cheap. The junk stock fuel pump runs off a designated cam lobe, and my cam lobe wore off...after lenghening(welding) the pump rod, it helped but not enough, after breking down multiple times and walking 8 miles through the snow, i put an electric fuel pump in and never had a problem..(its a common problem), otherwise they're hard to lift and get stuck easily, some(maybe all?) some with a limited slip rear end, so that's a bonus, they're too high geared(especially if you put bigger tires on, like 33's or 35's) so the clutches are known for burning up with normal abuse..good luck i'll never buy one again
    ~Mark~
  16. 85_SS_302_Coupe it sucks (I know) to be on the receiving end
    Nov 11, 2003
    Message Count:
    7,277
    125
    113
    Northern KY
    Dang! lol
    Ok so aside from offroading/lifting and all that, do they drive down the road sufficiently? LOL
  17. dastang2 Active Member
    Dec 12, 2003
    Message Count:
    2,058
    46
    tx
    i had an 84 with a 2.8 and automatic 4x4. it ran great but was too sluggish in the acceleration department. but in 4x4 it was awsome even with my bad shocks and street tires. my dad had a 2.9 in a ranger and it went for well over 200,000 until it was wrecked.
  18. RsStanG1987 I shaved all my pubes playing this game.
    Mar 13, 2004
    Message Count:
    1,292
    24
    48
    Dupont PA
    My friend had one with 89k miles and the rear locked up and we hit a pole. The girl in the front almost died and my friend eric was in the hospital for 2 days. i walked away without a scratch. His was and auto. It was a nice lil beater though.
  19. dastang2 Active Member
    Dec 12, 2003
    Message Count:
    2,058
    46
    tx
    wonder if the rear end leaked all the fluid out
  20. Mustang78 New Member
    Feb 8, 2006
    Message Count:
    494
    Aberdeen, WA
    probably...and they suck at high speeds, any jerk of the wheel at 60 is scary...they're unstable at speed, so be careful and dont teach your sister how to drive one on the highway..especially if it's her first time driving a stick and there's a steep cliff down to the water next to ya..lol(scary *****)
    ~Mark~
Share This Page
