The rear main seal is the same. The gear will work, but the speedo may not be right. I'm not sure about the 3550 gear ratios, I don't think they're the same as the T5- but physically it will work. Use the speedo calibration unit at Hanlon to see if you have the right gear
Well, it's the same as the early T5's -- which makes it a 7 tooth. The later T5's (90+) changed to an 8 tooth, so in that case it would be different. That's what I was trying to get at in my first post.
