- Mar 30, 2005
- 472
- 0
- 0
what kinda specs shoudl i get on my AOD? i mean valve body, shift kit, internals, stall?!?!?!? sorry, my recent post got deleted due to the crash, thanks!!!!!!!!!!!
New one-way-clutches and used a spiral snap ring on the intermediate one-way-clutch (the stock snap rings are known to fly off which I found the case with mine when disassembled.)
jaymac said:http://www.transmissionspecialty.com/parts/parts/76811-01K.htm
This is a link to a page for a spiral snap ring that I found-
Is this the same one you guys were talking about? My AOD's being done tomorrow, and I wanted to see if I could get my hands on one before then.
Thanks,
J
EMW150 said:I just built one for my wife's '87. Depending on the year of the trans, it'll have cast iron or stamped steel drums depending on the year. My trans is an '89 so it had cast drums but they used a stamped steel forward clutch in it. 1990 up used stamped steel drums. Here's a list of mods I made to it to make it take some abuse.
-Upgraded direct clutch to stamped steel and used an Alto 8 friction clutch pack in it. (the direct clutch has the most stress of all clutch packs - the stamped steel drums will take more abuse on the splines for the lock-up shaft)
- New one-way-clutches and used a spiral snap ring on the intermediate one-way-clutch (the stock snap rings are known to fly off which I found the case with mine when disassembled.)
- Forward clutch (stamped steel) - used 5 friction Alto clutch pack
- Reverse clutch - stock repl. alto browns
- Replaced all piston seals in clutches (*Need to buy seal installers - about $80.00)
- Red Eagle Overdrive band
- A+ Super Servo by Fairbanks (33 percent more holding power than stock)
- Sonnax boost valve and throttle valve.
- Zero leak 2-3 accumulator (stock for replacement for '97)
- Hardened lock-up shaft
- Edge Mild Street Convertor
- Transgo shift kit (if you're building for racing you may want to look at Lentech valve bodies or PA.)
I have probably about $1000.00 in it counting the Convertor but it should hold up well and shifts great.
bobbys9350 said:WOW! thankks for all the GREAT replies!!!!!!!!!! so i dont need a shift kti when getting a lentech valve body? also, what size stall for a daily driver and what brand?!?!?! THANKS AGAIN!!!
bobbys9350 said:thanks a lotg guys!!!!!!!! so the lentech street terminator is the way to go?
