Bad fuel pump symptoms
94blackgt 1621
79
What are some symtoms of a bad fuel pump, or a fuel pump that can't put out as much fuel as your car needs.
Right now I basically have long tubes, a trick flow street intake, and pulleys, and I ported out my stock heads a little.
My car out of nowhere started popping under load and hesitating. Could this be from a bad fuel pump?
have you pulled codes? do you have a FP gauge you can hook up to monitor pressure?
two major things control FP - the pump and the regulator. bad regulator will dump too much fuel and make it seem as though the pump is inadequate.
one would need to provide more info and do more testing to diagnose further (i too would not be jumping all over the fuel system w/o more info).
good luck.
one can run a 1000 GPH pump - if the regulator is working, fuel consumption will remain the same (you are simply pumping 97% of it back to the tank).
I had this same problem on my buddy's 91 GT. Turned out to be the electronics in the distributor. If you have a spare or know someone who does, drop that in and see if it cures it. It's an easy fix. Why order a new pump if the pressure is fine? Even with smaller injectors it should still run alright, you just won't have the power... your computer adjusts all this automatically. Your AF could be off too. Is your MAF calibrated? The problem sounds electronic related... not fuel. Just givin you a heads up.
Nick
