Not sure if i have any pics, but i'm hoping you didn't order the summit kit with the plasitc box. Kinda of makes the car look like you jacked a box off of someones camper.
Most tracks if not all won't let you run it. Besides it looks kinda of cheap.
The moroso kit and the summit built box both are approved though, so if you got one of them you are good to go.
I have the taylor, which is decent, not great, but alot better than the plastic box.
I ran the power cable throug a hole in the firewall, behind the kick plate, down past the seat by door sill in the bottom corner (you'll see other wires there) up past the rear seat around all the interior panels and to the licence plate where i put the disconnect (which i suggest the first time around). Not an ounce of it is showing or in a dangerous spot.
Grounded the battery to the quad shock mount.
I'm also told by a super reliable source that the computer should also be ground to the battery. with a #10 meaning run it the distance with the positive.
Some cars can do without this some can't. It's also recommended by pro-m if you use their meter.
Mines mounted on the passenger side with one bolt through the frame, and the other just though the floor.
