best ecu
Discussion in 'Fox 5.0 Mustang Tech' started by Doc90, Aug 16, 2006.
  1. Doc90 New Member
    Apr 18, 2006
    Message Count:
    38
    texas
    i need to get a new ecu i have 1990 notch and i need to know what ecu i need it is a 5.0, 5speed, i know that there are a bunch a9l, a9m i dont really know which is the best.
  2. tording Founding Member
    Nov 12, 2000
    Message Count:
    166
    Hampton, VA
    If your car is a 90 manual then the stock one should be an A9L. I would think that this would be the best since thats what it had. However I have heard that the auto computer (A9P) had a little bit different timing/fuel curve table because of the auto tranny to keep the HP numbers up a little bit. Not for sure if this is true or not.
    Sponsored Ad
  3. vristang Advanced Member
    Mar 31, 2005
    Message Count:
    4,654
    68
    Seattle
    Using the TwEECer to compare the A9L and A9P Sealevel Spark Tables, it does appear that the A9P has significantly more timing at high loads.
    The A9L seems to have more timing in the lower loads however.
    Many folks have converted to the X3Z computer from a 93 Cobra, but there is no real power advantage there. The X3Z requires a MAF modification as well.
    Stick with the A9* computers.
    jason
  4. bryce93lx New Member
    Jan 21, 2006
    Message Count:
    188
    15
    Luke AFB AZ
    auto computer will run a 5 speed car just fine and many prefer it, however a auto car must have the auto computer
  5. chevy_impala57 New Member
    Jun 20, 2006
    Message Count:
    I dont how this Auto computer stuff works exsactly internally. But I put A speed density computer thats was out of a standred car into a 5.0 aod toyota conversion. And i was worried about it not working But it runns just like Pony. And i was looking at the wiring digramps and it jsut looks to me all that really is diffrent is the Clutch switch, or netural safty switch.
    I aslo put a auto comp(A9p) into a 93 ford f150, with Mustang T-5 tranny
    I wish some one could explain why it "shouldnt" work.
  6. vristang Advanced Member
    Mar 31, 2005
    Message Count:
    4,654
    68
    Seattle
    I'm not really sure what you are asking?
    Your A9P wouldn't have any trouble with the manual F150
    I assume your toyota conversion was SD?
    What cannot be done is to run an Automatic Transmission with a Manual computer.
