BMR Adj. Panhard not adjustable enough?
RB2005
I bought thier adj. panhard with poly bushings. When I went to install it I figured I'd set it at the length of the stocker and work from there. Well, turns out it won't even adjust to the length of the stock unit, it's way too long. I need it to be shorter than stock now that my pro-kit is in.
I still like the pieces I bought from BMR. Has this happened to anyone else, or did I just get a bad one? The lower control arms that I installed are great though.
At least they've changed the adjuster to sit halfway down the bar. I had one of their APB on my Z28 and the adjuster nuts sat in a recess you couldn't get a spanner on. Stupid design. I also found out 18 months later that the adjusters had pretty much seized despite buying the chrome-moly rod.
