body harness question
Discussion in 'Fox 5.0 Talk' started by hsean, Nov 8, 2009.
  1. hsean Member
    Jul 25, 2006
    Message Count:
    461
    18
    dearborn,michigan
    i am using an 87 body harness with what i think is a 92 dash harness and 93 engine harness .this could be a problem i ran all my wires inside the car and it might not be compatible.anyone have this issue?should i try to find a 90 and up body harness.
  2. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,644
    9
    78
    Massachusetts
    I think 91-93 are the years you need for a compatible harness
  3. Chuckman Active Member
    Oct 22, 2005
    Message Count:
    442
    26
    st. louis, mo
    i know the 87-89 body harnesses are different, but shouldnt the 90-92.5 harnesses be the same except for options, and then after that the pump relay moved into the engine bay? or did that not mess with the harness and they just left that connector open? idle curiosity on this part.
    but yes, the 87 body harness isnt plug-and-play with the 90-up harnesses.
  4. hsean Member
    Jul 25, 2006
    Message Count:
    461
    18
    dearborn,michigan
    just came back from the junkyard they had a 91 4cylinder car that i spent 4 hours tearing apart.i took the dash and body harness so that i wouldn't have any compatibility issues.man my hands are all cut up there was glass everywhere from some idiots busting both quarter glass.
  5. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,644
    9
    78
    Massachusetts
    Morons. If they only knew how valueable those are.
    Every time i go to the boneyard i want to buy them off every Fox i see....if only it wasn't such a PITA
  6. hsean Member
    Jul 25, 2006
    Message Count:
    461
    18
    dearborn,michigan
    they were alittle sunbaked but they could have been fixed .i won't have to worry about mine because i'm installing the foureyed style in mine.
  7. 50foxbody Member
    Jan 5, 2009
    Message Count:
    220
    hsean your ready to show us some more update on your car :D
  8. hsean Member
    Jul 25, 2006
    Message Count:
    461
    18
    dearborn,michigan
    i guess i can show something i have to take all the interior wiring out but i did install something that came out real nice .i will post it in a few minutes i have to grab my camera.
Share This Page
