boost gauge
stang217
Long Island
my friend jus tput a procharger on his car... i bought him a boost gauge... i just wanted to know where i tap into to make it work... someone told me on the upper intake... he's also got an Oil preassure gauge.. where does that get tapped into... thanks
You could tap directly into any of the vacuum lines, so the gauge would read vacuum at idle and boost under pressure. I personally tapped the MAF adapter plate and put my boost gauge on that. So, if I'm at 700 rpm's or at 6000 rpms, I'm still showing boost.
thanks
where do you hook up the power for the lights and stuff also?
mines hooked up to the headlight fuse, sense the fuse box is right there..i assume u have it on ur pillar? just run then down behind the seal and down towards ur hood release, and pull the fuse for one of the headlights and wrap it around one of the prongs on the fuse and push it back in..that way they cut on when u cut ur headlights on..now someone might wanna say rather or not that is smart, because i really do not know, but i havent had any problems in over a year with the lights nor the headlights, so i dont think its a problem...and for the ground you just find something metal to ground it to, i believe there is a dimmer wire as well? d*** i so forget what its hooked to, id have to get back on you on that one
