brake fluid all over.....
Discussion in '2005 - 2009 Specific Tech' started by mustangmike6996, Jan 30, 2007.
  1. mustangmike6996 Member
    Nov 11, 2005
    Message Count:
    570
    clinton twp, MI
    anyone with a s197 and a brake fluid leak on the master cyl. i was told by ford(who talked to someone in the tech center) that this is due to depressing the brake and clutch pedal at the same time from the excess pressure build up. the tech center recomended that the dealership remove some of the brake fluid almost to the minimum fill line.
    has anyone else been told this same line... it sounds reasonable
  2. thump_rrr New Member
    Nov 26, 2004
    Message Count:
    220
    Montreal, Canada
    They are full of crap.
    The gaskets suck plain and simple.
    Some people have cut the lids from coffee cans or margarine containers and put a layer below the factory gasket to prevent leakage.
    I had my cap replaced twice to no avail.
    Pull your inner wheelhousing liner and check to see if the fluid didn't peel the paint off down there.
    If it did make the dealer repaint it under warranty to prevent rust.
  3. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
    many people have had good results with removing some of the fluid. i removed some of mine, and have not had any leaks in a few months.
  4. mustangmike6996 Member
    Nov 11, 2005
    Message Count:
    570
    clinton twp, MI
    i have already had it in for this concern 3 times. (lemon law????) just making it official. it ate the paint off of the frame rail they resprayed it under warranty. i even told the service advisor some of the cures for repairing the leak when i took it in today. i havent let the brake fluid get too far out of my control since the respray.
  5. NorthwestGT New Member
    Jan 12, 2006
    Message Count:
    177
    Pasco, WA
    I think you guys should badger your dealer to fix the leak under warranty. That is the only thing that worked for me. They replaced my brake fluid reservoir and it has not leaked since (more than six months so far). It is a defect in the moulding of the top of the lip where the cap is supposed to seal.
    Mustangmike, I had to take mine back to my Friendly Ford dealer twice before it was clear to them that there was something more to the leak problem than just a dirty seal in the cap. But, they finally did the fix.
  6. kooldawg6 mine works really well and can take a fair amount
    Aug 31, 2006
    Message Count:
    1,718
    Central VA
    :bs:
    That certainly is funny since mine is the automatic and did it as well...I too took the cap off, cleaned the cap and bottle real well and removed some fluid. No probs since(been about 3 months).
  7. Warlok New Member
    Oct 11, 2006
    Message Count:
    90
    YUP!
    I noticed the same thing on the top of the lip. I just took an exacto knife trimmed the top edge just enough to flatten the ridge and it seals perfectly. I never removed any fluid.
  8. NorthwestGT New Member
    Jan 12, 2006
    Message Count:
    177
    Pasco, WA
    Warlock, you know I was going to do that but I chickened out. Didn't want to risk getting any chips in the fluid. But, that is exactly the problem, bad seal from irregularities on that lip.
  9. cowtown Founding Member
    Nov 4, 2001
    Message Count:
    228
    Victoria, BC Canada
    Great tip guys, I'll have to do that. They replaced my cap last fall but I'm sure it didn't help.
  10. mikeelia New Member
    Mar 31, 2005
    Message Count:
    39
    SoCal
    Someone on one of the forums came up with another solution, which was buying a $.79 round neoprene gasket at a hardware store, and placing over the existing rubber seal [in the cap]. I did that and it seemed to work, though lowering the level of fluid a little seems like a good idea too.
    I also heard of one person that put a rag in the reservoir then sanded the MC lip smooth and that worked for him. I think the xacto method is pretty similar.
    Mike E
  11. metroplex Member
    Sep 7, 2003
    Message Count:
    401
    Wrapping the neck with teflon tape 3-4 turns will also fix the problem. My GT started seeping fluid the day it arrived from Flat Rock, MI.
  12. mustangmike6996 Member
    Nov 11, 2005
    Message Count:
    570
    clinton twp, MI
    i have tried the xacto trick and i am waiting for results. i just needed to get my car in there a few (3) times and have the paperwork showing that i have had this issue before, then if there is another problem in the future with the dealership being rediculous ill just make them eat the car and give me a new one.
  13. jay07 Member
    Aug 4, 2006
    Message Count:
    60
    I looked at my resevoir over the weekend and it doesn't seem to have any burrs and seems to be a pretty flat surface. How noticable is the uneven surface? I don't think mine has leaked yet, at least not to my knowledge. Any tips on identifying the defect?
  14. metroplex Member
    Sep 7, 2003
    Message Count:
    401
    If yours has not leaked, it won't leak. My Stang leaked the day it came home with 2 miles on the odometer (had just arrived from Flat Rock). Luckily I caught it and wrapped the neck with teflon tape for the time being. I may try the exacto knife method to smooth the top of the neck. Alternatively I may buy a new reservoir and true the neck surface and just swap the entire reservoir. I believe they just pop in/out?
  15. metroplex Member
    Sep 7, 2003
    Message Count:
    401
    Update: I took a careful look at my reservoir. Previously, I wrapped the neck with teflon tape and it did not melt. However, the teflon tape was soaked with brake fluid.
    I looked at the seal surface of the reservoir and cannot see how it is malformed or a "defect". The ridge appears to be part of the molding or design. A soft gasket is designed to form itself to minor irregularities, and this ridge is just designed to further improve the sealing.
    I think there are several things in common with the various fixes:
    Using a rag stuffed in the reservoir to prevent plastic chips from falling in while smoothing out the neck. This may soak up or absorb some of the brake fluid in the reservoir.
    Having the dealer swap reservoirs several times until one no longer leaked. It's possible the fill level was different, with the most recent reservoir not filled as much as the others resulting in the leak being fixed.
    Lastly, the obvious solution is to remove some of the brake fluid from the reservoir.
    There's a slit cut in the center of the gasket, and if the fill level is too high, some of the brake fluid can shoot right through this slit, onto the back of the gasket, and drains out through the cap. That's my theory at least.
    A fix would be a revised cap gasket with a smaller slit, or the center piece located MUCH higher to prevent sloshing brake fluid from seeping through the slit.
  16. Mark25 Member
    Jul 31, 2006
    Message Count:
    92
    Virginia Beach, VA
    I took some cotton tubing (my wife gets them at a nail salon) and cut two one and half inch pieces and place each piece at opposite ends under the cap (front one facing the radiator) and the other piece facing the firewall...I use a flat tip screwdriver to get them shoved under the cap...it's been 9 months and I haven't seen a drop of brake fluid anywhere...the cotton must be absorbing any excess that comes out.
Share This Page
