Brake Rust
Discussion in '2005 - 2009 Specific Tech' started by jyanny, Jul 5, 2007.
  1. jyanny New Member
    May 15, 2006
    Message Count:
    I just put on 20" wheels w/ Michelin PS2 255/30/20 Tires on my '07 Mustang GT Convertible. It looks great but now after last nights rain I noticed the brake discs are showing rust.......anything I can do to prevent or remove this.
  2. Spdfreak New Member
    Feb 21, 2006
    Message Count:
    281
    Drive it around the block and stop several times.
  3. stanmckinney Active Member
    Mar 31, 2005
    Message Count:
    1,180
    38
    Same problem here. Same solution.
  4. homebrewer New Member
    Nov 13, 2006
    Message Count:
    80
    Richmond VA
    The stock brakes will start to show rust 20 minutes after the rain. As others said, just drive it around the block. If you want to permanently prevent this, go get some larger aftermarket rotors that are plated to complement those larger wheels. No rust, and bigger brakes, how can you go wrong?
    The more important question (to me at least), is why do you have a stock width tire on a 20" wheel? If I was going to spend the money on wheels, I'd definitely get some wider tires to help with traction a bit. Personally, that will be one of my first mods. I guess I'm just curious as to why.....
  5. cLeAnRaCiNgLdR New Member
    Dec 7, 2004
    Message Count:
    98
    stock width is 235
    they are probably 20x9's...Don't want to go to much wider with the tires.
    Anything but those crappy Ford brakes will be a permanent solution, driving around slamming on your brakes is a temporary one.
Share This Page
